1 - 2 of 2 Posts
new to owning a mach. what is the largest lug and stud that you have run on your mach, or what is your sujestion
Lug 1.25 max, no stud. If you plan to use studs you need to keep the stock 0.8 inch track with 1.1 studs but be prepared to install protection for the heat exchanger and bulkhead, oh and keep the track tension tight.
1 - 2 of 2 Posts
