I need to know if i just adjust that little block from 1 to 3 for more ski and less track ( weight transfer ) if not what else is involved?
How do i lower the pressure on that front coil shock to see if that will help top end? is there a bleed valve or something? mines covered in snow!!
have to pull her in tomorrow i guess
thx in advance
There was a very good post a while back i think by Rob, on susp. setup. Just do a search. Let rear susp. hang,back off on spring until it's loose, then tighten turn turn & a half. same with ski shocks this is start point.
