1 - 14 of 14 Posts
· Registered
2000 miles. Any impressions on this sled? Any problem areas with this year and model? What do they average for mpg? Power valves?
· Registered
Good sled! I have a '98 (basically the same sled) and have put 6500 miles on it. Fun chassis. 11 mpg when stock, whether ridden tame or hard. Decent top end, but not exactly the best in the low to mid range. With the D&D single pipe, chip, and clutching I am getting 12mpg and similar performance to the later model valved 600 twins (600 xc, 600 zr apv). Been running that setup for the past 5500 miles with no problems. Only problem has been the stator. My first one burned out at 3000 miles - Cat covered it. At the end of last season I burned out the second stator and will be buying a new one this fall. Good suspension for the rough, could use a 2" riser on the handles. Intake noise is obnoxious - sounds like crap and makes your ears ring at the end of the day. But the damn sled is pretty fun as long as you don't expect it to pull on your arms like an 800.
· Registered
Boy, I see alot of posts about the stators going out on these sleds. How much is it to replace one? Is there any way to check for a bad stator before buying this sled?
· Premium Member
Stator, TSS (throttle safety switch) and recoil. Other than that, great sled. I have a 98 as well.
· Registered
I have had more problems with piston than anything on my 2 600's. The stator did go out on my zl at 7500 miles, and my zr has 12,000 miles on it and the stator is still fine. Those sleds need to have the top ends done every 3500-4000 miles or else you are looking for a burn down. Other than that you can pound the crap out of it and will take it just fine.
· Registered
<div align="right">index.php?act=findpost&pid=894797
YOU GET 11MPG STOCK. hOLY SHIT. mY 98 RUNS GREAT BUT IVE SEEN BETTER MPG ON A 440. i AM LUCKY TO BREAK 8MPG CRUISING. i HAVE A CHIP IN IT BUT DOESN'T HELP A BIT. Everyone esle I ahve asked said they couldnt get decent mileage unless they piped it.
· Registered
Yeah, I've never dropped below 11 mpg even when ridden hard. I am also running a fuel pressure regulator, though, and I keep my fuel pressure set at 38 lbs. It is possible that some of the poor mpg sleds might have fuel regulators that are out of wack.
· Registered
both of my sleds will see 10-12 trail cruiseing same with everyone else I have ridden with that had a zr6. Riding them hard will make them get 8-10. Both are stock efi sleds. One is a 99 and the other is a 2000. Have you ever had your EFI scanned to see if everthing is working correctly. My dads old ext efi started useing loads of gas when the temp sensor went out.
· Registered
great all around sled. mine has been very reliable too.
efi is great. never taken more than 2 pulls to start, even after it sat all summer.
105-110 for topend is a bit of a strech unless you have a 40mph tailwind :smilielol:
can't always rely on those cat speedo's. :div20:
1 - 14 of 14 Posts
