Hey guys
My girlfriend drives a 1992 440 indy, I noticed the end of last season it was sitting low. This year i took out the suspension in the rear and re-did it all, new springs and shock, but it seems to sit low stil, is this just how that model will ride? Is there a cheap fit to make it ride higher??
thanks
my buddy did mine so i dont accualy know exactly how, but mine sits 16 inches from the floor to the bumper
you could use the drop brackets that are on the bottom of the tunnle. this will make the rear sit a little higher and will add ski pressure which would probably make the sle handle better for her, and yes they just sit that low, my uncle had a 95 xlt that he re did everything and even after it was still a low rider, as is my g/f 94 indy trail. Over the summer I am going to rebuild the rear skid and then use the lower drop brackets instead of using the bolt holes in the tunnle, hope this helps.
