Looking to see best head design for 1004 with bored out 900 cylinders are and desired squish?? Running pump 91 to 92 octane. Attachment the circle numbers are my current setup and the others are a design I think are from some one on here? Or are some after market better?? Scan0012.jpg
Discussion Starter #3 (Edited)
So Auggie does your sketch still stand or have you got improvements to it?? Also what squish do I want to end up with running 91 octane?? A certain range of compression? If I use your design I will put the motor together cut the 900 heads as you say then adjust it to the squish you recommend for that design of head. As stated in my base gasket question it will vary on the setup/ gaskets I end up using on the base with my 900 bored cylinders. I know .018 will make a difference on the squish for sure.
