Are the overall lengths the same? Besides that check outside diamter differences for the lower chaincase bearing. If that bearing can be swapped it should work....hopefully. Why do you want to do this btw?
I wanted to put no slip sprokets on my 1" drive shaft, but I found an edge drive shaft with no slip sprokets on it already. I know the shaft size is larger on an edge. I think it is 1 1/8" or 1 1/4". I was just wondering if it would work.
