1 - 7 of 7 Posts
I just went for a ride today and the sled ran fine for about 50 miles. I stopped at a gas station to top it off and about 5 miles after filling up, it started spuddering at about 4000-5000 rpm. For the rest of the ride the engine light flashed and I could only ride about half throttle, any more and it would die out. If any one has any ideas or know what it could be let me know. thanks.
Have you tried a little dry gas for starters, then I'd replace the fuel filter.
Sounds like a fuel issue since it started after fueling up.
My buddy has the same year and engine and his was doing the same thing. It ended being something electrical like a sensor but I'm not absolutely positive. Could definitely be bad gas though.
If it were the tether, the motor wouldn't tach high enough to engage the clutch and it also would beep 4 times letting you know it was either a bad connection or dirty contact.
1 - 7 of 7 Posts
