Does a 2005 Fusion have a master fuse somewhere?
Lost headlights, tail light, display and hand warmers...
Still runs, electric start works, reverse works just nothing else. Read a couple things online that said voltage regulator. Changed that today (aftermarker Reg),with no change. Appreciate any help.
The vr replacement to fix those symptoms is for the 06 600HO carbed Fusion. Not the 05/06 900 cfi’s.
Here is a tidbit i found on the cfi’s
“The symptoms of a bad chassis power relay are lights,handwarmer, instrument etc not working at all or flickering.”
I would use that relay as a search term and see if others have found the same thing.
There is more covered in threads you'll find, like shorted brake lights/shorted hand warmers/etc...so go thru each one by one. Some just require unplugging things to find out.
  • Like
Reactions: bbezok
