Was that under warranty? Im at 127# 900km aprxI you still have the stock 2005 900 pistons you may want to visually inspect your pistons from the exhaust ports. Mine had 125 psi of compression in both cylinders by the mag side piston and cylinder were stuffed bad. The dealer installed the updated 2006 pistons with two new cylinders.[/b]
one of my pistons hooked the port and put a knick in the ring and a small flake of nic chipped off. it resulted in a 10 pound comp loss. i had no second year warranty. dealer got 2 pistons and i new cyl warrantied for me. :beerchug:I heard if it aint blown up no warranty. I gues you take the belt off and put a zip tie on the throttle while your taking it in.[/b]
