1 - 2 of 2 Posts
I have an 04 ZR 900 Efi with 136 that I just bought and it has heavy hitters in now, I have 0 experiance with this set up, but if it doesn't work I would like to find out what does. This set up might work great, I have no seat time on it at all, but if it doesn't then I will do something different. Has anybody got any good experiance with this clutching or any others that work good? Thanks :dunno:
Contact Dan at THE OUTDOOR SHOP. My '04 ZR 900 efi is down there right now getting the clutches set up. I am not sure if your long track will change the helix angle required for the driven clutch. Is the stock 50/36 degree one in there now? Do you know what rpm's it was turning at full throttle? It should be around 7200. What size heavy hitters are in there now? Have you thought about getting the secondary upgraded to the 10.4" (06 spec). As you can tell I have been researching this topic, and I will post my results as soon as the snow comes. :stirthepot:
1 - 2 of 2 Posts
