Have you ever done it on any other sleds before? If so then it will be simple and you will know what to do.
Hey man i just took my track off for the first time myself...what i did was tied the back of my sled up, removed my belt and secondary clutch, exhaust, and can, then my rear suspention, then remove ur gear casing and your gears, then move to the gold plate around the shaft, then i went to the other side below the secdary and removed the 3 bolts from the speedometer cable and wiggled the drivers around a little and pushed the shaft threw then poped the beared off on the gear case side and i was all done...hope it helped :beerchug:
