1 - 2 of 2 Posts
stock clutching,yellow white primary,65 gram weights,2ndary green spring with 58-52 helix and 031 belt.running 8100-8200 on long pulls.what would a 020 belt do for rpms with the stock clutching?i really like the durability of the 031 kevlar belt,can the chaincase sleds pull the 70 gram cat weights like they use on the 05-06 f6 with diamond drive?maybe a cat orange white primary,cat 70 gram set screw weights and leave the 2ndary alone since the helix is already pretty agressive,was also thinking about trying the 035 belt which is slightly wider than the 031,may ride a little higher on the primary at full shift and give a little more top end?thanks for any info.
I think Dan from The Outdoor Shop got me a set of either 67 or 68 gram Cat weights which is what I'm goung to try in the wifes sled. Her's revs almost the same. Just no snow here to try it.
1 - 2 of 2 Posts
