1 - 2 of 2 Posts
can you use any old o-ring on the pins like the ones you find in the hardware store or are they made of a special material,the ones on the left side of the weights are cracked and split,can you also get a roller and bushing kit for the spider or do you still have to buy the whole spider.thanks.
I think they are made from Viton so any O-ring made from that material as long as it's about the same size will do. They are cheap from the dealer. I completely removed mine on the thrust side and replaced it with a nylon washer for that very reason. There is sooooooo much load put on them that the o-rings don't last more than 800-1000 miles before they split and fall out.
As for the roller kit, one from an old cat 9 post is a direct drop in. I have used part numbers from a 99 Tcat as the doner and the parts are exactly the same.
1 - 2 of 2 Posts
