have an 800 pro-x 2, and trying to find where the hole is in the water pump belt cover to view the timing marks? i had the cover off earlier in season to replace water pump belt and see no hole whatsoever . can anybody help me? , im trying to see if the timing is off, has poor top end perf. thanks
Facing sled on the mag side look down by the coolant bottle its a "D" shaped hole on top of the rewind housing. make sure tps is disconnected @ 2000 rpm 28 deg some are set at 30 deg. dont go any more than 30 deg. are you running pods? They will make it run rich. which will affect your top end. Bruce
no, not running pods. i have air box gutted and installed the SLP air horn intake kit. main jets 430.
