1 - 2 of 2 Posts
Just got it running and I'm looking for a better set up clutch is stock 440 set up for 121, gearing is stock. Looking for same gearing but better clutch set up and carb set up. Thanks
Since no one else is jumping in to help I'll give you my set up. I have an '02 Pro-X chassis with an '01 440 and a 136x1.5 RipSaw. Here's my set-up I got from Pockets.......
Your stock gearing should be fine. I run 19/42 for a 2.21 ratio and the sled pulls with authority! See how your 19/43 pulls and change gears if you don't like it. For clutching, stay with the stock almond/red primary spring with S53H weights. The motor won't pull the S55H's with the longtrack. In the secondary, the R49 stock helix (52/34) is ok, or a HSP 52/34S. I'm running a Dalton 52/34S and it shifts great. The blue/orange secondary spring #2, or the silver/blue #2 or 3. Buy new springs....... your clutches will be happy you did! I would run 2001 needles in #2 with a half step shim, I found #3 too rich unless it was below 0F. Air screw at 2-2.5 turns as well. Set the idle to 2-2500 rpm hot engine.
Once you get it dialed you'll love it!! Good luck!
SK.
1 - 2 of 2 Posts
