Since owning my sled new I havent been able to solve my belt problem. I constantly blow belts. I have taken my sled to the dealer and everytime they cant figure out what is the cause. The motor is aligned and the belt area has been sealed incase moisture is causing the belt to slip and heat up then shread.
I have used both bombardier gold belts ( with top fins for additional cooling) as well as dayco ultramax 3 belts. Both of these belts ended up the same way. In the bush or ditch blown apart.
Anyone have any ideas what could be the cause.
Thanks
probably the problem. You should always check the clutch alighnment and center to center on a regular basis. You should also change the springs.
Never assume it was correct from the foctory. When properly set up these things should hold a belt for an easy 1k plus even modded. I usally have them wear som much they get the jitteries on take off.
