1 - 20 of 24 Posts
I believe that I am going to just use my spdwrx pipe and a 2.5 key. What RPM should I try and run this at. I hit about 7600 right away, and then climb to 7800. Where does this pipe make peak HP and Torque? Would this change if I decide to go with the Speedwerx1000 PAC system and lean out the top end? :help:
I have the D&D kit right now and have had great luck with it. I would hate to go to lighter weights to bring up the RPM. The only other option would be to call D&D and see what to do. Maybel a different primary spring. I have the secondary second from the tightest right now. I don't think the pipe and the key are going to make enough power to bring my rpm up 200+. This will be the first year with the pipe and key. any suggestions?
I wonder if it would be a good idea to take a little weight off of the tips of the Big Dog weights. This should bring the top end rpm up. I don't know exactly how much to start with for about 200 rpm. Any suggestions? Thanx, J.
I am looking at my dyno sheets with the same mods [pipe and key] and my sled makes over 100lb. ft of torque from 7500 to 7900 by 8100 I have lost 5lbs and 3.5 HP. My HP peak is 152.5 at 7700 rpms,also peak torque was 104.8 at 7600. As you can see I have one of the good running 700s,your numbers might not be the same but your powerband should be close to the same. I hope this helped you.
Be carefull of overreving as my sled goes wicked lean at 8100 [EFI]
Good luck,
Dave :beer:
                                    Good luck,
                                    Dave :beer:
<div align="right">index.php?act=findpost&pid=939307
What year is it? And can you post those sheets?
Thanks
Discussion Starter · #8 ·
What key are you running? Are you running a fuel reducer or anything else besides the pipe? Please let me know. I f you could, please post your dyno sheets or pm me with them. That will help me clutch mine as well. As you said, the power band should be the same.
Discussion Starter · #10 ·
Bikeman and Luke, you say it runs the best at 8000 to 8100....is this tested with long runs w/ lots of heat in the pipe, or short 1000ft runs? Have you dynoed this or not? Not questioning your findings, just trying to get a good hold on this topic. 7700 to 8100 is a huge difference when trying to setup the clutching. thanks guys!
Discussion Starter · #11 ·
just got off the phone w/ Speedwerx, and they do say 8000-8100 on heat soaked motor. 69.5 gr. weights and tit. blue spring, 165-310.
<div align="right">index.php?act=findpost&pid=940704
Seems like an awful lot of weight for a stock '03 motor with just timing/pipe/FP restrictor...I would think 66g's would be plenty...ecspecially if you want to pull 8100 rpms.
Discussion Starter · #13 ·
i'm going to run home and check and see what weights I'm running with my D&D clutch kit. I thought the big dog weights were heavier than 69.5 though. I'll check.
Discussion Starter · #14 ·
I tried to look at mine and it was hard to see the weight on the side. It says D&D and then I swear it says [email protected]?#>#@. Could that be right? They are big dog (heavy tip) weights.....if that helps. What is stock?
Discussion Starter · #16 ·
I can't believe that Speedwerx recommended using 69.5 weights and running 8000-8100. That must be one hell of a spring in that primary.
<div align="right">index.php?act=findpost&pid=942346
Could have confused it with an '04? :dunno:
I am using stock ZR900 80 gram weights with orange white trimmed the tips so I have 76.6 grams over all, with the stock helix & spring with the spring tension in @.375.
Mike
1 - 20 of 24 Posts
