Drove 2 hrs up to NH to ride. Started the sled up and it sounded a bit odd. So I started riding it and first noticed that the rpm gauge is bouncing all over the place....like saying 9000 rpm when its more like 2000-3000 etc. So I opened the hood and checked a bunch of the connectors, which didn't do anything. So I tried going a bit and it has no power, can't even come close to spinning the track. Feels like it almost surges a bit, but it may be the clutch just opening up. Sounds like its in safe mode?
Anyone have any clue whats going on? I took all the connectors off and cleaned/di-electric greased them after my ride 2 weeks ago when the hot light came on for no apparent reason...oh and the hot light went away after I cleaned the connectors.
Its an 03 F7 EFI with around 1500 miles on it.
Check your main ground[/b]
Where is the main ground on this sled?
I tested the AC voltage at the high beam headlight, like the service manual says. At idle I was getting around 12.2 volts and as I revved it up (can't see what rpm I'm at...maybe 3000-4000 ish by sound) the voltage was going down to around 7ish. The manual says I should get around 12 to 14.2 volts at 3000 rpm and to replace the voltage regulator if you get over 14.2 volts.
Its an 03 F7 EFI with around 1500 miles on it.[/b]
Did you check for chaffed wires?
Did you check for chaffed wires?[/b]
I searched around and will again when its light out tomorrow. I unplugged and replugged all the harness connectors I could find. Got the rpm gauge to idle normal and rev up normal with the hood closed after. Then I opened the hood abouut 15 min later and tried again and the RPM gauge is all over the place once again.
