1 - 16 of 16 Posts
350s - All three F5s - (Engines stock) other then clutching
-20 below to whatever - Trails and lakes
Zero issues - Great piston wash and plug color - A combined 20,000 miles between all three F5s
Wisconsin and U.P. riding elevation
340 mains with clips 4th clip from the top, 35 pilots, things is wicked snappy :div20:[/b]
:withstupid:
Just did a 100 mile ride at -20* with no issues, only differance is I am sitting middle clip position. FC5SP and I have been sharing info and have almost identical setups.
will take a true reading of the plugs after the break in gas has run it's course but the plugs are already looking better. EGT temps are good too.
I may run my bore scope down the cylinders this weekend and see whats going on
I've done testing at ZERO degrees with 350's for half mile runs. Plugs still black. Stock engine. NO additional timing.[/b]
F5's have a sensor in the pipe to advance timing in accordance with expansion chamber temps.
If plugs are BLACK with 350's I would look at your oil mixture, unless your at altitude.
1 - 16 of 16 Posts
