The warmers dont work..took and traced to the double plug for the handle bars and the test light lite up but I could not get a voltage read out, went to the extra plug by the head light and could not get a voltage read there either..took a pair of handle bars from a 600 and pluged into the double plug and they worked....there are 3 wires yellow green black ...should they all have power ...what type of voltage...
Check ohms in the handle bar elements, easiest way to diagnose. Should be reading some sort of resitance (can't remember how many ohms). If you don't get a resitance reading in the element plug ins then you have a break some where in the elements. Can be fixed, just need to find the break, remove the plastic shield covering the element (obviously after you have removed them from the handlebars), saulder the break, cover it with some apoxy glue or some sort of sealant, test them again to make sure you got all the breaks, then put them back on.
A little expanding foam inside the bars works wonders also,Insulates the bars keeps the heat where it belongs.
