I was wondering if there was anything wrong with the 020 belt? The reason I ask this is because when I put on the orginal belt(020) I get a hesitation at wot, I thought at first it was because the belt was getting old, so I bought a new one. The new one did the same thing. So then I tried an a ZRT 800 belt (010) and this solved my problem. So I was wondering what would cause my 2 blets to do this, Fault in the belts or is it something elese?
The 020 and 010 are different widths. The 010 is 1/32" narrower I am pretty sure. I know for sure it is narrower. Don't know why the performance difference on the F7 though. It should make it worse.
Cat S.
I had a bog off the line,put on a 010 no more bog,i don't know what it is...maybe the engine has to be lined up.
Did anyone try a 012 for drag racing,the 010 stopped the bog off the line and seem to pull harder,but only tried it for a short distance,i think the 010 is shorter...it has one less lug than the 020. B)
