Can anyone help me out?I recently puchased the sled and the prior owner had changed the needle jet to position #4,and 330 mains as he had a power breather.The sled now has the stock air box,Ive jetted it down to 290 main,but I'm at a loss as to where to locate the e-clip on the needle.I ride at about 1000 feet.Thanks alot
I would assume the stock location is the third or middle postition but a quick call to your local dealer and they should be able to confirm. If in doubt go rich.........its cheaper.
Rick.
Discussion Starter #3
Thanks, the 2001 performance maual says #2,Browns leisure world parts micrifice says# 2...called cat today they say #4.......I give up! by the way I found my APV cables to be not with in spec!Looks like Cats problem with cables is more wide spead than just the Firecat 5's
Yes the cables can be an ongoing issue for some, on my sled adjusting them every 1500 miles or so seems to do the trick.
Strange how your getting so many different answers, maybe call a couple of dealers for the info.
Rick.
