1 - 8 of 8 Posts
mm dealer told me that 800 mxzs are over geared from the factory. 26-43 stock. i have 25-43 with a 121x1.5 track. dealer thinks 21-43 would work better and also be easier on belts. any thoughts?
this sled is eating a belt every 200 miles and clutches have been aligned. having trouble with torque arm coming loose, loctite this time. might have to try a cudney kit plus a gear reduction. hope it won't beat my tcat 1000.
Sounds like a drive axle bearing then, or a broken motor mount, if the clutches are aligned wright you should get 1000 or 1 good season. something else is wrong. Are you using the stock 127 belt?
Discussion Starter · #7 ·
Sounds like a drive axle bearing then, or a broken motor mount, if the clutches are aligned wright you should get 1000 or 1 good season. something else is wrong. Are you using the stock 127 belt?[/b]
gone through 2 127 and 1 dayco hpx bought the sled couple months ago with 903 miles on it.
1 - 8 of 8 Posts
