Can you fit the 02 handlebar on a 01 riser for a 01 ZR and will everything switch over without much problem especially the heating elements?
Thanks
Jim
My brother just bought a 2001 ZR 800 that had the 2002 handlebars. The dealer said they had to raplace the whole steering column , it cost the previous owner @ $600.00! My brother loves them.
Discussion Starter #3
No I only want to add the 02 handlebar to the 01 riser set up. I know it is a problem if you want to add the entire 02 system to a 01 but I thought it may work just with the bars on my 01 riser.
Jim
The bars themselves can probably bolt to your stock 01 riser, but the problem is that the bars are a straight-across style bar. Your 01 bars have the hand grips about 3" or 4" above the mounting position. You'll need an extra 3 or 4 inches of riser to compensate.
