My 01 has burned pto pistons every 20 miles.Three so far.Just got the sled so I don,t know history.Took motor all the way down thinking bad crank seal.(looked ok) Has the updated needles (3rd clip) position 300 main jet. Timing -2.Am I missing something? Any one have any luck making these things live?
ide do a leak down test, find a mechanic friend who has the kit... and figure out the problem instead of making more scrap aluminum, thats gotta be getting expensive! if both carbs are bang on, and clean... you definately have an air leak somewhere to lean it out within 20 miles. carb boots, crank seal, hairline crack in case halves???
ide do a leak down test, find a mechanic friend who has the kit... and figure out the problem instead of making more scrap aluminum, thats gotta be getting expensive! if both carbs are bang on, and clean... you definately have an air leak somewhere to lean it out within 20 miles. carb boots, crank seal, hairline crack in case halves???[/b]
could be the carbs i have a like new pair for sale
http://cgi.ebay.com/ebaymotors/ws/eBayISAP....cSELL.m315.lVI
