1 - 7 of 7 Posts
I am looking for a good crankcase for my 02 pro x 600 and I found a 01 xc 600 case and I see the part numbers are different.Can someone tell me what the difference is?
as long as you're talkin about a ves motor it should be the same... i don't think the big block was available in 01, but can't remember...
Still looking for an answer. Please
Thank you[/b]
If it calls for the same crankshaft and its a 600 ves non HO it will work.
Should be the same from 2000-2005 . The 2004-05s use a different water pump drive gear
If you have a 2001 crank then use a 2000-2003 water pump.
Corrections are welcomed.
1 - 7 of 7 Posts
