Fuel sock replacement - HCS Snowmobile Forums
Rush/Switchback (AXYS Platform) This is a brand-specific forumand a 100% NO BASH Zone. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Old 03-17-2020, 11:32 AM   #1 (permalink)
Default Fuel sock replacement
What are the steps to replace the fuel sock?
SB00 is offline   Reply With Quote
Old 03-17-2020, 12:11 PM   #2 (permalink)
Are you able to buy just the sock? I have looked up parts fische and it shows whole unit, with pump etc. I see SPI makes socks, but have only found the ones for RMK. Same? Sorry to hijack, but looking to do this as well.
Thumb2bar is offline   Reply With Quote
Old 03-17-2020, 12:23 PM   #3 (permalink)
Current Sled(s): 2013 Rush Pro R 800 retro 2001 XCSP 700
19-20 Mileage:
18-19 Mileage: 1400
17-18 Mileage: 1200
16-17 Mileage: 1000
I believe that is what is in mine, the Spi one. I know if you go on Bikeman's site under Rush pro R, they sell just the sock.
Frankie406 is offline   Reply With Quote
Old 03-17-2020, 01:13 PM   #4 (permalink)
1995xcr600's Avatar
I believe just the sock for an Axys is Part # 2205699. I haven't been able to find an aftermarket one that is the same size/shape/length.
1995xcr600 is offline   Reply With Quote
Old 03-17-2020, 01:25 PM   #5 (permalink)
19-20 Mileage:
18-19 Mileage: 1400
17-18 Mileage: 1200
16-17 Mileage: 1000
Sorry, this is the Axys section. Not sure if they are the same part or not.
Old 03-17-2020, 02:26 PM   #6 (permalink)
Methinks you are correct. It has a zig zag shape.
https://www.ebay.com/itm/Polaris-KIT...gAAOSwyVRdW6Xt
Old 03-17-2020, 03:54 PM   #7 (permalink)
Current Sled(s): 2019 pro-s 850 SB
Previous Sled(s): 2016 pro-s 800 SB
Riding Since: 1967
Why can't they just be cleaned and reinstalled?
ray j is offline   Reply With Quote
Old 03-17-2020, 03:56 PM   #8 (permalink)
19-20 Mileage:
18-19 Mileage: 1400
17-18 Mileage: 1200
16-17 Mileage: 1000
They probably could be.
Old 03-17-2020, 06:23 PM   #9 (permalink)
Current Sled(s): 2016 800 Switchback Pro S
Previous Sled(s): 1995 Polaris XLT
Favorite Riding Area: North Shore area and Isabella
19-20 Mileage:
18-19 Mileage: 800
Riding Since: 1972
Copied and pasted from the service manual.
1. Remove the screw securing the seat to the seat
bracket. Remove the seat.
2. Remove the engine compartment side panels.
3. Remove the hood assembly.
4. Remove the air intake plenum.
5. Remove the fuel cap. After the cap is removed,
remove the filler neck nut. After removing the nut,
reinstall the fuel tank cap. Remove the console.
NOTE
Do not untie the recoil handle. Lay the console to the
side of the vehicle.
6. Remove the screw securing the front fuel tank
bracket to the fuel tank.
7. Remove the screw securing the fuel tank to the rear
track shock mount.
8. Disconnect the fuel supply and return hose
connectors from the fuel pump flange assembly.
NOTE
Note the position of the supply and return fuel hoses.
When the tank is installed on the vehicle, the RED
supply connector is located on the MAG (right) side of
the pump flange and the BLUE return connector is
located on the PTO (left) side of the pump flange.
9. Disconnect the fuel pump wire harness.
10.Remove the fuel tank from the vehicle.
FUEL PUMP REMOVAL / SERVICE
1. Follow the procedure for fuel tank removal.
2. Use the PFA Nut Socket (PS-48459) to remove the
pump flange nut.
PFA Nut SocketPS-48459
3. Carefully extract the fuel pump out of the fuel tank.
Manipulate the pickup assembly q to fit through the
tank opening. Do not kink the fuel pickup hose during
this process.
4. Discard the pump flange gasket.
WARNING
Do not re-use a pump flange gasket after the vehicle
has been put into service. Always use a new gasket
during assembly.
5. Inspect the fuel pickup assembly (sock). The pickup
must be replaced if it is damaged or contaminated
with foreign material.
FUEL PUMP INSTALLATION
1. Obtain a new pump flange gasket. Install the gasket
into the tank opening.
2. Reinstall the fuel pump assembly. Carefully
manipulate the float arm and pickup assembly
through the opening. Do not damage the gasket
during pump installation.
NOTE
Verify the fuel pickup assembly routes down the left
side of the fuel tank (as viewed from sitting on theseat).
3. Align the fuel pump flange assembly index marks with
the arrow on the fuel tank (A)
4. Install the flange nut. Use the PFA Nut Socket (PS-
48459) to torque the nut to specification.
Torque
Fuel Pump Flange Nut:
28 ft-lbs (38 Nm)
5. Complete the installation process by following the
Fuel Tank Installation Procedure.
dean_s is offline   Reply With Quote
