No start after spring maintenance? - HCS Snowmobile Forums
Rush/Switchback (AXYS Platform) This is a brand-specific forumand a 100% NO BASH Zone. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree7Likes
Old 06-08-2019, 12:41 PM   #1 (permalink)
Current Sled(s): 18 800 SB XCR, 17 600 Voyager, 14 900ace
Previous Sled(s): Poo's, Doo's and Yamadogs
Favorite Riding Area: Weld, Byron, Andover area
Riding Since: 1990
Default No start after spring maintenance?
Just got done going through my 2018 Switchback XCR 800. Drained gas and added aviation fuel, removed belt, picked the seals and greased the jack shaft and driveshaft bearings, removed battery, changed chain case lube and set tension, removed and cleaned the exhaust valves/ports and then fogged lower end through transfer ports... Put the hood on and plugged main harness together. Went to pull start to distribute fogging oil and nothing. Would not fire and the info center does not light up (blue) while pulling it over. Thought maybe the battery had to be installed to complete circuit, installed and starter turns the engine over fine but still no fire and no blue back lit display on the dash? I do not have a repair manual (need to suck it up and get one) can anyone give me an idea of where to start and where the fuses are located? Maybe a famous relay problem? Any help is much appreciated, thanks in advance.
Picky137 is offline   Reply With Quote
Old 06-08-2019, 01:28 PM   #2 (permalink)
fourh-ds's Avatar
Current Sled(s): 00 XCR 800, 04 XC 800
Riding Since: 1988
I've never worked on one of those, but you mentioned the main harness. If you haven't yet, check it good for broken pins or wires inside the plastic part of the plug. I've seen harnesses have broken wires or pins after someone pulls them apart roughly.
fourh-ds is online now   Reply With Quote
Old 06-08-2019, 01:43 PM   #3 (permalink)
xcbuc's Avatar
Current Sled(s): '17 XCR 800 / '07 600 CFI Switchback
Previous Sled(s): Polaris: '98 Indy Trail, '03 700 Edge
19-20 Mileage:
18-19 Mileage: 1900
17-18 Mileage: 1141
16-17 Mileage: 1200
Riding Since: 1991
Turn kill switch off. Holld wfo and pull over 3 time. Then turn kill switch on and try to start. I hold throttle at 50%.
I've had to do this 3 times the last 2 seasons. Starts every time after the no start symptom.
Sent from my moto x4 using Tapatalk
xcbuc is offline   Reply With Quote
Old 06-08-2019, 05:19 PM   #4 (permalink)
Riding Since: 1990
I'll be dammed!! Did as you instructed and it came right to life. How in the world did you discover that sequence? Is it only when battery voltage is removed and it resets the ECU or something. Don't think I read that in the owners manual! LOL Many, many thanks.
Old 06-08-2019, 07:45 PM   #5 (permalink)
Favorite Riding Area: Ma.
19-20 Mileage:
18-19 Mileage: not much
Riding Since: 70 s
Next time, just add stabil, fog it, and put it away.
Lexuslover likes this.
Old 06-08-2019, 08:38 PM   #6 (permalink)
xcbuc's Avatar
19-20 Mileage:
18-19 Mileage: 1900
17-18 Mileage: 1141
16-17 Mileage: 1200
Riding Since: 1991
Good deal! Thank others here on HCS!
Seems to happen every so often.
Old 06-08-2019, 09:59 PM   #7 (permalink)
Riding Since: 1990
Av gas has zero ethanol, 110 min. octane and a two year shelf life. Love that stuff for storage, even add stabil for old time sake Lol. Lucky I can buy it at a local municipal air port with a flight school. At only a little over $5/gallon its great stuff.
Old 06-09-2019, 09:07 AM   #8 (permalink)
northstarrick's Avatar
it was flooded from fogging oil and av gas. av gas is meant to be used at high er altitude where the air is colder. so the reed vapor pressure is higher than pump gas. this the oil and the outside temp is why it flooded. with the kill switch off and holding the throttle wide open and pulling it over you pushed the rich mixture out of the ex,.
Stage 1,2,3 clutch kits
Oil tank vent kits
Doo T-Stat bypass kits
Rush/Axys A-Arm bushing kits
550 fan upgrade kit
Authorized dealer for
SLP
RK-Tek
WPS
US Chrome
Thunder Products
Automatic Distributors
Venom/Team Ind.
Redline Oil
Klotz Racing Synthetics
K100
Old 06-09-2019, 10:04 AM   #9 (permalink)
19-20 Mileage:
Riding Since: 70 s
Well, hope you have better luck with av gas then i've had as far as sleds go. I had no issues with it in bikes, but for some unexplained reason the sleds didn't like it.
Old 07-08-2019, 09:28 AM   #10 (permalink)
SouthernTierSwitchback's Avatar
Current Sled(s): 2020 Indy XC 850 137
Previous Sled(s): 2016 Switch Pro S, 2005 XCSP 600, 2003 classic touring 700,
Favorite Riding Area: WNY / North Country
19-20 Mileage:
18-19 Mileage: 875
17-18 Mileage: 270
16-17 Mileage: 1380
Riding Since: 1978
I left some high octane VP in my motocrosser and it really screwed up orings and seals over the winter. From the petcock right through to the carb. Sucked. Wont do that anymore. Drain the shit out and dump it in the truck and call it a day
Two eyes... Two ears... One Mouth... Ever wonder why?
SouthernTierSwitchback is offline   Reply With Quote
