Rush/Switchback (AXYS Platform) This is a brand-specific forumand a 100% NO BASH Zone. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited. |
LinkBack | Thread Tools |
#1 (permalink) |
![]() Super Advanced Member
Current Sled(s): '15 Axys 800 SB 60th Anniversary
Previous Sled(s): '18 600 SB Founders Edition, '04 Polaris 700 Classic M/10
Favorite Riding Area: Northern WI, my trails in Iowa
19-20 Mileage:
18-19 Mileage: 800
17-18 Mileage: 970
16-17 Mileage: 840
Riding Since: 1980
OK I know it's summer..well close anyway.
Went to the trailer to check things out and realized that when I loaded my sleds in the trailer I left the key on on my '15..oops dead battery.. Well, gave it a couple pulls and bang, off she went. Let it idle for a few minutes revved a couple times. Turned off the key, hit the kill switch. Hooke the battery up to battery tender. Now two days later..battery still dead. (no biggy it's still the original)...here's the kicker...SLED WON'T START! WTH? kill switch up, key on pull several times and nothing..went as far as unhook the harness to the hood. Still nothing. Change plugs as they seemed pretty wet. Still nothing..Gave the throttle a little crack..no fire. What gives? two pulls the other night and now nothing.. Anyone have answers? This is going to drive me crazy ![]() ![]()
"If at first you don't succeed, skydiving's not for you." To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
Sponsored Links | |||
#3 (permalink) |
battery has nothing to do with ignition on Polaris sleds. the only sleds effected by low voltage ( under 10 vdc) are ski-doo S.D.I. and E-TEC'S. the ecu shuts down under 10 volts won't start even pulling it. one reason ski-doo got ride of recoils on some models. you can't start a C.F.I. sled and not let it run up to temp or you risk flooding it'
pull both plugs. with the key/kill switch off pull it over 10 plus times. put new plugs in it and it should fire right up. warm weather starting compounds the flooding issue.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Northstar Performance Products Stage 1,2,3 clutch kits Oil tank vent kits Doo T-Stat bypass kits Rush/Axys A-Arm bushing kits 550 fan upgrade kit Our products have been race tested and proven all across North America! Authorized dealer for SLP RK-Tek WPS US Chrome Thunder Products Automatic Distributors Venom/Team Ind. Redline Oil Klotz Racing Synthetics K100 |
#4 (permalink) |
19-20 Mileage:
18-19 Mileage: 800
17-18 Mileage: 970
16-17 Mileage: 840
Riding Since: 1980
Thanks Northstar. I'll give it a go. It's a dome scratcher for me as I have never had any problems at any time with this sled not starting. Especially since it started on the first pull 2 days earlier.
#5 (permalink) |
19-20 Mileage:
18-19 Mileage: 800
17-18 Mileage: 970
16-17 Mileage: 840
Riding Since: 1980
Update.
Took one of my trolling motor batteries and some small cables and hooked to the dead battery. Gauge started right up..turned key..spun but didn't engage to the fly wheel..weird, but one pull fired right off. I let it run up to about 130 and shut it down. Unhooked the battery and pulled three times and nothing. Hooked back to the good battery and one pull. Ran it for a bit and called it good. Loaded all the stuff back into the truck and gave the sled one more pull, fired right up..helped my buddy do a tire rotation on his truck and before I left his place decided to give it another try. One pull away she went..let's hope when I put the new battery in it it will engage the starter like usual.
#6 (permalink) | |
19-20 Mileage:
18-19 Mileage: 849 so far
17-18 Mileage: 1280
16-17 Mileage: 1115
Riding Since: 1982
![]() Quote:
It might be that the bad battery is directly shorted and is drawing all the DC current from the stator. If so, you should try disconnecting the ground cable from the dead battery. It should fire right up. ![]() |
#7 (permalink) | |
19-20 Mileage:
18-19 Mileage: 800
17-18 Mileage: 970
16-17 Mileage: 840
Riding Since: 1980
![]() Quote:
#9 (permalink) |
![]() Newbie
I had the same issue, one my battery went dead, I could not revive it with a charger. Starts 2nd pull everytime, but not with the battery. It will not engage the flywheel. I am getting a new battery and hope I do not have to replace the starter, but I think I need t. I will replace battery first.
#10 (permalink) |
A short in the battery shouldn’t affect starting with the rope. There is a chassis power relay that doesn’t allow any power to anything that’s not needed for startup.
Sent from my iPhone using Tapatalk |
Sponsored Links | |
Thread Tools | |
Thread | Thread Starter | Forum | Replies | Last Post |
Help! NEW cold start problem | bcporsche | SR Viper | 29 | 05-08-2019 06:53 AM |
Electric start problem on 15 X gade 800r etec | rbeland | REV Chassis | 0 | 03-11-2019 11:21 AM |
97 Touring E 380 help, no start | enick72 | ZX Chassis | 0 | 12-17-2018 12:45 PM |
2016 M8000 Wont Start | Diamond Ranch | ProClimb (2012 - ) | 11 | 03-02-2017 05:26 PM |
2012 Switchback Assault won't start... | Grateful Sled Head | Switchback Assault/RMK (Pro-Ride Chassis) | 21 | 12-18-2016 08:25 AM |
