2017 600 ProS Fuel Mileage & Clutch ?'s - Page 2 - HCS Snowmobile Forums
Rush/Switchback (AXYS Platform) This is a brand-specific forumand a 100% NO BASH Zone. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree2Likes
Old 03-21-2018, 03:20 PM   #11 (permalink)
snohawk's Avatar
Current Sled(s): 2017 XCR 600, 16 Indy 600 SP TD, 15 Indy SP
Previous Sled(s): 2011 600 PRO R, 07 IQ 600HO, 07-05 XC500SP, 02 XC600SP
Favorite Riding Area: Northeast WI
19-20 Mileage:
18-19 Mileage: 1600
16-17 Mileage: 1250
Riding Since: 72
I have a 17 XCR 600 and normally get around 14 mpg riding tight woods trails and open flowing forest roads. My sled does engage around 4000 rpm. I did noticed towards the end of the first first that the sled engaged hard and found the drive belt loose. Could your wife sleds belt just need to be tightened up?
snohawk is offline   Reply With Quote
Old 03-21-2018, 03:31 PM   #12 (permalink)
edgexcsp's Avatar
Current Sled(s): 2020 SBA 850
Previous Sled(s): 19 Indy XC,17 SBA,17 ProS 600 SB, 14 SBA 800, 09 D8,03 500
Favorite Riding Area: Off the beaten path
19-20 Mileage: 804
18-19 Mileage: 1380.9
17-18 Mileage: 1481
16-17 Mileage: 1152
Riding Since: 1990
I didn't measure the deflection but it did not feel loose by any means. I will check it for sure later today.
SNOWMOBILING- MONEY WELL WASTED
edgexcsp is offline   Reply With Quote
Old 03-21-2018, 03:35 PM   #13 (permalink)
tie rod's Avatar
Current Sled(s): 2019 Polaris 850 Assault SBA
Previous Sled(s): 2018 Polaris XCR 800 SWB; 2015 Polaris 800 Pro S SB
17-18 Mileage: 2000
Originally Posted by edgexcsp View Post
Originally Posted by Deephaven View Post
Sounds like something is wrong with the clutch. My buddy has his 600 wound out when we are riding and even in heavy, wet snow he gets better mileage than that. His 600 is a kitten compared to my 800 as well.
That's what I am worried about but it doesn't act like anything else is wrong and I have not noticed an abnormal belt issues.
nothing is wrong with your sled. My 15 600 SWB engages hi and has pathetic MPG.
tie rod is offline   Reply With Quote
Old 03-21-2018, 03:49 PM   #14 (permalink)
snohawk's Avatar
19-20 Mileage:
18-19 Mileage: 1600
16-17 Mileage: 1250
Riding Since: 72
I usually tighten the deflection so that the track will just baring rotate be itself when on a track stand
Old 03-21-2018, 05:49 PM   #15 (permalink)
ivar's Avatar
Current Sled(s): 2019 SBA 850
sounds like somethings sticking a little bit...? I'd pull the clutch cover + spring, put the cover back on and verify that sheaves moves nice & smooth
2019 SBA 850,2015 600 Adventure (int'l)
09 Doo 1200 GTX, 02 XC800 / 00 XCR800 - Pro-X rear skid, 99 XC700SP
RIP: 800SBA, 02 XC800, 99 SKS700, 97 XLT SKS
ivar is offline   Reply With Quote
Old 03-24-2018, 11:58 AM   #16 (permalink)
edgexcsp's Avatar
19-20 Mileage: 804
17-18 Mileage: 1481
16-17 Mileage: 1152
Riding Since: 1990
Thanks for the suggestions guys, season is over here at this point so I'm planning on going through everything good over the summer. I'll probably end of changing the secondary spring to help w/ the fuel mileage some.
Old 02-13-2020, 08:06 AM   #17 (permalink)
jdw1's Avatar
Current Sled(s): 20 XC 800 137 16 SB Pro S 8, 03 pro x 700
Previous Sled(s): 12 Pro RMK 8,05 SB 8,00XC SP 6.
Riding Since: 1964
I realize this thread is almost 2 years old but my wifeís 17 600 seems to be harsh/high rpm at engagement also, like 4100-4200, just wondering if you ever resolved your wifeís clutch engagement issues @edgexcsp
Someone suggested a 120-330 primary spring, Iím thinking of trying that, I looked a a red venom spring but i think itís a 140-320 so thatís not going to help with engagement on takeoff.
Thanks in advance!
Sure, weíll let you lead, just as long as you can keep up!
jdw1 is offline   Reply With Quote
Old 02-13-2020, 09:27 AM   #18 (permalink)
patrioticinnovations's Avatar
Previous Sled(s): 2003 XCR 1100, 2000 XCR 800 turbo, 2005 Redline Revolt 800.
19-20 Mileage: 715 so far
18-19 Mileage: 849
17-18 Mileage: 1280
16-17 Mileage: 1115
Riding Since: 1982
Should be simple to lower engagement rpm.
1. Use a new proper width belt.
2. Set deflection as tight as possible.
3. Make sure both clutches aren't sticking.
4. Then, if necessary, use a lower initial tension spring around 100-120 lbs. Finish tension can stay as stock or slightly higher.
Old 02-13-2020, 10:35 AM   #19 (permalink)
jdw1's Avatar
Riding Since: 1964
Thank you sir!
Disassembled primary clutch yesterday and cleaned, yes it was dirty so it could have been hanging up, tower tolerance was about .0045 so that might have added to the issues, having clutch balanced and then reassemble and set tower tolerance and belt tolerance, it was about .050, that was ridiculous!
I put my calipers on the belt, 1.46, not that It really matters, my wife is 65 and doesnít do a lot of hot rodden like she used to, really no abuse to the belt whatsoever on her part, I know thereís other factors involved on belt ware. Checking clutch Alinment and such, just wondering if edgexcsp ever resolved his/her issues.
Thanks for the advice patrioticinnovations I appreciate it!
Old 02-14-2020, 02:37 AM   #20 (permalink)
pockets's Avatar
Current Sled(s): 2018 600 Voyageur
Previous Sled(s): 1996 440 XCRSP, 2000 XCR 800, 2006 600 RMK 144
Favorite Riding Area: Northern Saskatchewan
Riding Since: 1994
Originally Posted by jdw1 View Post
I realize this thread is almost 2 years old but my wife’s 17 600 seems to be harsh/high rpm at engagement also, like 4100-4200, just wondering if you ever resolved your wife’s clutch engagement issues @edgexcsp
Someone suggested a 120-330 primary spring, I’m thinking of trying that, I looked a a red venom spring but i think it’s a 140-320 so that’s not going to help with engagement on takeoff.
Thanks in advance!
Put in a venom yellow 120/340 primary spring. In the secondary put in a 140/220 black/green, along with 3 delrin washers. One on each end of the spring, one under the spring cup.
The lower engagement spring will make it engage softer, and the different secondary spring will lower cruise rpm and improve mileage and acceleration.
pockets is offline   Reply With Quote
