Help! NEW cold start problem - HCS Snowmobile Forums
SR Viper This is the section for Tech talk and discussion for the New SR Viper. This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree8Likes
Old 03-12-2019, 12:38 PM   #1 (permalink)
bcporsche's Avatar
Current Sled(s): 14 Viper 19 Rush
Previous Sled(s): 1980 Polaris Centurion, 79 Kawaski Invader, 03 Viper
Favorite Riding Area: Andover & Rangeley Me.
18-19 Mileage 2800
17-18 Mileage: 1800
16-17 Mileage: 1476
15-16 Mileage: 1677
Riding Since: 1984
Default Help! NEW cold start problem
Ok just went on 4 day trip.
- Left home (4deg) started FINE, just turned key, like I've done for past 3 yrs. (200 mile day)
-Next day (-2deg), turned key, started but stumbled so I touched throttle and then stalled and wouldn't start (flooded). Dealer said I shouldn't touch throttle and suggested hold 1/2 throttle and don't let off key. Well it started and held high throttle until warm. ran great and started great all day. Thought I was all set. (300 mile day)
-3rd day, (5deg), tried to start, almost did, major back firing. Was going to have local dealer pick up but after and hour or so we got it to start. Still brought to dealer for new plugs and reflash. Dealer also said to cycle key twice and then start.
-4th day, tried 2 cycle key trick, but start great for 20 seconds and then stumbled. I finally played with throttle to keep going until warm. Fine all day with numerous starts. (made it home)
Next day at home (12deg) tried my old way to start, started but then started to stumble after 30 seconds, played with throttle and kept it going.
WHAT IS WRONG????? Asked dealer, he said probably needs valve adjustment (expensive) sled has 8300 miles. Don't want to say he is wrong, but up to 3 days before it always started fine, even in colder weather.
ANY OTHER SUGGESTIONS? Throttle adjust? Bad sensor?
2014 Yamaha Viper (all stock, original owner, always maintained well)
Live Now-Pay Later
bcporsche is offline   Reply With Quote
Old 03-19-2019, 07:56 PM   #2 (permalink)
bcporsche's Avatar
18-19 Mileage 2800
17-18 Mileage: 1800
16-17 Mileage: 1476
15-16 Mileage: 1677
Riding Since: 1984
After more investigation;
1. I turn the key it starts fine and idles normal
2. It idles for 10 seconds normal then begins to idle lower until it stalls
3. Will now not start without giving it gas
4. It will start and idle really rough almost like it's running on 2 cylinders
5. It will only stay running if I keep the rpm over 3000
6. If keep the rpm over 3000 until the coolant temp is over 70 it will now idle normal
7. If I drive it after it's warmed up it drives normal
Live Now-Pay Later
Old 03-19-2019, 08:13 PM   #3 (permalink)
cfm
Current Sled(s): 900 Fuse-10,200miles and going / 06 600HO M10
Riding Since: 3 BC
do these have Idle Speed Valves? Sure sounds like an issue with one...but one needs diagnostic equipment( software/hardware to watch sensors live / fuel psi checker / spark strength checker / etc) to zero in on the problem like coolant temp sensor and other common problems.
PPP Charter Member #2
Old 03-19-2019, 09:33 PM   #4 (permalink)
Fun11cat's Avatar
Current Sled(s): 2020 ZR 8000 LTD IACT - 14 XF7000 Ltd
Previous Sled(s): 10 F8 SP,05 F6,02 ZL 600SS, 99 ZL 600, 96 Pantera
Favorite Riding Area: Central MN
18-19 Mileage 1170
17-18 Mileage: 1260
16-17 Mileage: 960
15-16 Mileage: 849
Riding Since: 1972
@bcporsche Maybe its the ISC relay that is sticking try one of the other relays from headlight/taillight easy thing to try.
cfm likes this.
Fun11cat is offline   Reply With Quote
Old 03-24-2019, 08:17 PM   #5 (permalink)
bcporsche's Avatar
18-19 Mileage 2800
17-18 Mileage: 1800
16-17 Mileage: 1476
15-16 Mileage: 1677
Riding Since: 1984
I tried switching relays and Unhooking battery with key on trick. Still the same. I guess its valve adjustment time as dealer suggested
Live Now-Pay Later
Old 03-26-2019, 02:00 PM   #6 (permalink)
fastcat800's Avatar
Current Sled(s): 2014 XF 7000 SP LTD, 2006 M6
Previous Sled(s): 2006 XF 700, 2001 ZR 800, 1996 ZRT 800
Favorite Riding Area: MN's North Shore and ID, MT
18-19 Mileage 1985
17-18 Mileage: 2525
16-17 Mileage: 960
15-16 Mileage: 2410
Riding Since: 1971
I think paying to have the valves adjusted would be a waste of money. It is something electrical or fuel related. It would not run fine when warm if the valves were out of adjustment. Check the compression. If it is normal it is not the valves.
bcporsche likes this.
fastcat800 is offline   Reply With Quote
Old 03-26-2019, 02:45 PM   #7 (permalink)
awful knawful's Avatar
Current Sled(s): 2019 Expedition Sport 900
Previous Sled(s): 1992 MXXTCR, 74 TNT 300
Out of spec valves usually show as hot start issues.
awful knawful is offline   Reply With Quote
Old 03-26-2019, 04:11 PM   #8 (permalink)
mrbb's Avatar
Current Sled(s): NA
Previous Sled(s): T cat's, zrt's ZR's, xf 7000, wildcat and a bunch of others
Favorite Riding Area: Pinedale WY
18-19 Mileage 450
17-18 Mileage: 1100
16-17 Mileage: 750
15-16 Mileage: 100
Age: mr
Riding Since: 1977
did you replace the OEM NON sealed relays with sealed one's?? if not I would start there!
mrbb is offline   Reply With Quote
Old 03-26-2019, 04:19 PM   #9 (permalink)
bcporsche's Avatar
18-19 Mileage 2800
17-18 Mileage: 1800
16-17 Mileage: 1476
15-16 Mileage: 1677
Riding Since: 1984
I agree, the problem started just out of the blue. (see my post)
Dealer is adamant that its a valve adjustment, wont even entertain other ideas.
Live Now-Pay Later
Old 03-26-2019, 04:24 PM   #10 (permalink)
bcporsche's Avatar
18-19 Mileage 2800
17-18 Mileage: 1800
16-17 Mileage: 1476
15-16 Mileage: 1677
Riding Since: 1984
I switched IEC relay as someone mentioned, no change. I don't think its a relay issue. (I've seen those problems in wifes Vector) But my Viper starts for 10 seconds then after 10 seconds idle drops and stalls. When trying to re start you hear fuel pump and popping. Like its flooded or something. Once over 90 on engine temp, starts and idles fine. MAYBE AND IDLE CONTROL UNIT?
Live Now-Pay Later
Similar Threads
First start... no start Picky137 Rush/Switchback (AXYS Platform) 20 01-29-2019 01:22 PM
2010 800 Dragon SB cold starting issues mbcuz38 IQ chassis 28 01-18-2018 10:47 PM
Cold start? 04redsnopro Turbo 4 Stroke 2 12-28-2017 02:31 AM
800 long cold start DaSm86 ProCross (2012 - ) 14 12-24-2017 03:58 PM
April, In Like a Lion, Cold Temps, More Snow gadedude07 Maine 6 03-31-2016 08:07 PM
