Trailer Deck - HCS Snowmobile Forums
Snowmobile Trailers & Haulers Section for discussions about trailers & other ways of hauling snowmobiles.
Like Tree2Likes
Old 10-11-2019, 09:43 PM   #1 (permalink)
600Triple's Avatar
Current Sled(s): 06 crossfire 7
Previous Sled(s): 96 ZRT600, 02 ZRT600
Favorite Riding Area: minnesota
Riding Since: 1995
Default Trailer Deck
I'm in the process of replacing the deck on my sled bed v front trailer. I've done some searching but saw mixed reviews about what type of plywood to use. Any help/info is appreciated.
600Triple is offline   Reply With Quote
Old 10-11-2019, 11:49 PM   #2 (permalink)
PolarcatJimmy's Avatar
Favorite Riding Area: Speculator, NY
Riding Since: 1978
Marine grade ply
PolarcatJimmy is offline   Reply With Quote
Old 10-12-2019, 11:33 AM   #3 (permalink)
Newbie
Current Sled(s): 2014 Indy LXT 550
Previous Sled(s): 1999 Indy 500
Originally Posted by PolarcatJimmy View Post
Marine grade ply
2nd this. For a bunch or reasons including strength, rot resistance and and exterior grade glue.
fishhard is offline   Reply With Quote
Old 10-12-2019, 11:56 AM   #4 (permalink)
mrbb's Avatar
Current Sled(s): NA
Previous Sled(s): T cat's, zrt's ZR's, xf 7000, wildcat and a bunch of others
Favorite Riding Area: Pinedale WY
19-20 Mileage:
18-19 Mileage: 450
17-18 Mileage: 1100
16-17 Mileage: 750
Age: mr
Riding Since: 1977
yes marine grade, or if just treated plywood, make sure its rated for round contact, its treated better, than the lesser NON ground contact treated wood!
and make sure you use chemical resistant hardware to secure it down
treated wood chemicals will eat certain metals!
mrbb is offline   Reply With Quote
Old 10-12-2019, 04:24 PM   #5 (permalink)
JHELREY's Avatar
Current Sled(s): 2015 XRS 800
19-20 Mileage:
18-19 Mileage: 1050
I just used exterior grade plywood and painted the topside.
By the time the wood rots out, etc. You can replace it again for less than you will buying marine.
JHELREY is online now   Reply With Quote
Old 10-13-2019, 01:11 PM   #6 (permalink)
600Triple's Avatar
Riding Since: 1995
Thanks for the replies so far, I've heard that marine is the best but was looking for other opinions. I've also heard not to use regular treated on aluminum as it will cause corrosion?
mnstang likes this.
Old 10-13-2019, 01:50 PM   #7 (permalink)
mrbb's Avatar
Current Sled(s): NA
19-20 Mileage:
18-19 Mileage: 450
17-18 Mileage: 1100
16-17 Mileage: 750
Age: mr
Riding Since: 1977
I have used regular treated ply wood on my trailers in the past, never had any reaction from it and the aluminum frame< its on there a good 15+ yrs now too
BUT when you mix METALS with aluminum, you will get a reaction, and this is why they place sacrificial things between trailers frames and the axle mounts! to try and curb the reactions from the different metals !
treated wood will eat steel hardware, screws and bolts over time'
and why you need to use either aluminum or stainless steel, or other wise Coated screws rivets/bolts when using in treated wood!
Old 10-13-2019, 05:50 PM   #8 (permalink)
Newbie
The copper in treated wood does discolour and corrode Aluminum. This impacts fasteners more extensively and quickly b/c it's surrounded and embedded in the wood and I've seen flashing chewed up in relatively short order. It could be that treated wood laying on a much thicker gauge box tube frame would be a slower reaction but I still wouldn't personally do it without putting something b/w the two (e.g. thin rubber sheet).
IMO marine ply is still the best option followed by a good quality sheet of exterior ply that you've gone over to make sure it's the best of that batch (avoid sheets with lots of voids b/w plies, de-lamination of plies, large knots holes, etc.). It's most important to make sure the adhesive in the ply is meant for exterior otherwise moisture will simply cause it to fall apart.
Of course use and abuse matters. Is this sitting outside flat all the time with water pooling on it? or will you keep it covered and/or tilted to have the water run off? Is it in the sun or shade? In the city or country? At our cabin on the lake, things decompose a lot faster then they do at my primary residence near the city.
Old 10-13-2019, 05:53 PM   #9 (permalink)
Newbie
I tried to post this but failed. If it comes up twice, my apologies.
The copper in treated wood causes the reaction; it does discolour and corrode Aluminum. This impacts fasteners more extensively and quickly b/c it's surrounded and embedded in the wood and I've seen flashing chewed up in relatively short order. It could be that treated wood laying on a much thicker gauge box tube frame would be a slower reaction but I still wouldn't personally do it without putting something b/w the two (e.g. thin rubber sheet).
Old 10-13-2019, 06:05 PM   #10 (permalink)
600Triple's Avatar
Riding Since: 1995
Yes that's what I read as well on the green treat, my trailer has a channel that the ply goes in so a layer between would be almost impossible. My trailer does sit outside all the time as I dont have room for it inside.
