Want locks for trailer doors - Page 3 - HCS Snowmobile Forums
Snowmobile Trailers & Haulers Section for discussions about trailers & other ways of hauling snowmobiles.
Like Tree6Likes
Old 05-14-2019, 07:01 PM   #21 (permalink)
mrbb's Avatar
Current Sled(s): NA
Previous Sled(s): T cat's, zrt's ZR's, xf 7000, wildcat and a bunch of others
Favorite Riding Area: Pinedale WY
18-19 Mileage 450
17-18 Mileage: 1100
16-17 Mileage: 750
15-16 Mileage: 100
Age: mr
Riding Since: 1977
Originally Posted by stinkipinki View Post
Unless you get in through the door/locks, getting into an Enclosed trailer is not an easy task, well not with my Car Mate, maybe a cheaper knock off like Rock Solid. They are re-enforced panels with steel framing.
If I locked somebody in my enclosed with nothing but their bare hands, they are not getting out very easily.
Using examples like a grinder and large bolt cutters is also a little extreme, they make locks that cannot be cut with bolt cutters.
I am not disagreeing with you that, if someone TRULY want to get in, and no ones around, they can and will, but some of those are extreme examples.
again, MOST pad locks a simple Harbor freight cheap op bolt cutter will slice right thru
MOST all enclosed trailers have THIN aluminum skin on them and many GLUED on to framing, framing is mostly aluminum on snowmobile trailers and at 12-16 inch spacing,
a hammer and screw driver will make a decent hole pretty fast if one wanted to!, and once they get a hole started simple tool can make things WAY bigger real fast
again, if anyone wanted in a trailer, its NOT hard to get in, GETTING larger things out might be a bigger problem, till they get a ramp door open
and MANY trailers have the hardware that HOLDS ramp doors on, on the outside, so simple tools like socket wrench or cordless impact gun, can remove the whole hinges off the doors?
again, the harder you make things, the more likely they will pass and target easier things to take
but there not mush required to get into a trailer when you DON"T care about the damage you do , doing so!
locks really work on honest people , crooks??
all comes down to how skilled they are and how bad they want in!
mrbb is offline   Reply With Quote
Old 05-14-2019, 09:54 PM   #22 (permalink)
Member
Current Sled(s): 06 Attak 14 Renegade X ES
Previous Sled(s): 1992 Polaris Indy 500
Favorite Riding Area: Northern MI
16-17 Mileage: 500
15-16 Mileage: 2500
Riding Since: 76
Default Locks
Originally Posted by jethroxlt View Post
All these cores are far less deep than a typical truck key core. Like 1/4 as deep. You can get new cores easy, but keying to a typical truck key is not possible unless you want to spend an unrealistic amount of money to fabricate new cores and door hardware from scratch.
I think he is referring to the Cap on his Truck which has a similar lock as the trailer ..
You can purchase a key based on the number stamped on the tumbler..
Skibum46mi is offline   Reply With Quote
Old 05-14-2019, 10:34 PM   #23 (permalink)
Member
16-17 Mileage: 500
15-16 Mileage: 2500
Riding Since: 76
Default Locks
https://www.etrailer.com/dept-pg-Tra...railer%20Locks
Old 05-16-2019, 11:20 AM   #24 (permalink)
jethroxlt's Avatar
Current Sled(s): 2019 Ski Doo Renegade 900T Enduro
Previous Sled(s): Yamaha, Cat, Polaris
Favorite Riding Area: Allagash
18-19 Mileage 950
I think you could kick yourself out of my EZ Hauler in less than a minute even if you were wearing flip flops.
mrbb and stinkipinki like this.
jethroxlt is offline   Reply With Quote
Old 05-17-2019, 12:41 AM   #25 (permalink)
Current Sled(s): 2018 ProS 800 SB
Previous Sled(s): 2005 XCsp 700, 2001 Edge XCR 800, 2003 Edge 700
Favorite Riding Area: Cable, Wi.
18-19 Mileage 928
17-18 Mileage: 1,125
16-17 Mileage: 596
15-16 Mileage: 740
Riding Since: 1967
Search "global link locks".
I was going to order an RV door lock and compartment lock so all my trlr & camper locks were keyed the same with just 1 extra key. You can order them to be keyed the same as an existing global key you already have.
I did see some locks that can be keyed same as a vehicle, but I didnt want that at the time.
NEED2SNOW (I NEED 2 SNOWmobile!)
2003 700 XCsp, 136" stretch, PERC, SLP Single
2001 Edge/XCR, 136" "Switchback" triple! Flannery Trail Ported, HTG Edge Pipes,
2005 700 XCsp, M-10 with Jack, E-Start, 2003 600 Edge "X"
need2snow is offline   Reply With Quote
Similar Threads
Proven Industries trailer locks! res2cue Snowmobile Trailers & Haulers 15 07-25-2018 12:50 AM
What lubrication for locks? teamgreen711 Snowmobile Trailers & Haulers 14 01-18-2017 03:31 PM
Ramp doors Cat Family Snowmobile Trailers & Haulers 14 12-08-2016 11:02 PM
Fuel doors highflyer Snowmobile Trailers & Haulers 30 04-19-2016 09:38 AM
