Whiteout Project - Page 3 - HCS Snowmobile Forums
Snowmobile Trailers & Haulers Section for discussions about trailers & other ways of hauling snowmobiles.
Like Tree95Likes
Old 10-29-2018, 09:47 PM   #21 (permalink)
calltrex's Avatar
Current Sled(s): 2019 850 Assault 144
nice ideas. reverse lights good idea but its not a big trailer so can see good. Also i would have to switch to a round trailer plug if i want it to come on if i put it into reverse.
If i want to i could just turn the rear loading lights on i just installed. All lights inside and loading lights will have there own power from batt inside. dont need truck hooked up.
Heres rear and side LED light bars. aluminum 45degree lights. pretty bright.
ID:	2025620   Click image for larger version
ID:	2025622   Click image for larger version
ID:	2025624   Click image for larger version
ID:	2025626   Click image for larger version
2019 Lima Build
2019 Trailer Build.
2017 Switchback Assault 800 Build Here.
calltrex is offline   Reply With Quote
Old 10-29-2018, 11:06 PM   #22 (permalink)
Current Sled(s): Not enough room to list my 6 Polaris's
Previous Sled(s): probably 12 Polaris', 10 Yamaha's, 10 Skidoos, zero Arctic C
Riding Since: 1964
It would be nice if you posted a link to where you get your accessories like you did with the Black Scorpion project
decee is offline   Reply With Quote
Old 10-29-2018, 11:43 PM   #23 (permalink)
mrbb's Avatar
Current Sled(s): NA
Previous Sled(s): T cat's, zrt's ZR's, xf 7000, wildcat and a bunch of others
Favorite Riding Area: Pinedale WY
19-20 Mileage:
18-19 Mileage: 450
17-18 Mileage: 1100
16-17 Mileage: 750
Age: mr
Riding Since: 1977
I wasn't sure if your trailer had e brakes or not
BUT when I did my trailer, also NO brakes and a standard 4 way pin connection
what I did, was I simply added a 4 way truck side pigtail and then got one of these
https://www.etrailer.com/Wiring/Epicord/277-000141.html
converting my set up to a 7 way, YET if ever wanted I can simply unplug things at pig tail and I have my original 4 way as a back up of sorts,
with the 7 way I then could have lights come on when I am in reverse real simple like deal
maybe not needed on your trailer, but back up lights in general I think should be on ALL trailers, there is NO down side to them IMO
mrbb is offline   Reply With Quote
Old 10-30-2018, 12:00 AM   #24 (permalink)
calltrex's Avatar
Started parts list on first post
Trail Ryder likes this.
2019 Lima Build
2019 Trailer Build.
Old 10-30-2018, 09:46 AM   #25 (permalink)
snowtime's Avatar
Current Sled(s): 17SBA8ES
Previous Sled(s): 11SB6ES, 01XC5SP
Favorite Riding Area: Seney
19-20 Mileage: 1
18-19 Mileage: 635
17-18 Mileage: 680
16-17 Mileage: 630
Riding Since: '99
Any Solar power in the works? Been thinking of adding a solar panel to charge the battery on my trailer. They also make Solar powered LED lights for RV's that come in handy. I used a solar powered RV porch light with a motion sensor on my shed up north
I was thinking of adding a few of these to my trailer ceiling. One over the entry door and one over the ramp.
https://www.etrailer.com/RV-Lighting.../ILL28CMB.html
2017 SWITCHBACK ASSAULT 800 ES WITH 2" TRACK, GRIPPER SKIS, AND 6" SHAPER BARS
Previous: '11 POLARIS SB 600ES, '01 POLARIS 500XCSP, '98 ARCTIC CAT ZL500
Trailer: '18 R&R 714FE
snowtime is offline   Reply With Quote
Old 10-30-2018, 12:42 PM   #26 (permalink)
calltrex's Avatar
Thought about a small solar on roof but dont really need one. Could leave my lights on for days.
Installing a nice 110 port right now and will have a waterproof 10amp charger on it inside to maintain batt
When its parked in my garage just plug it in from outside
Can run any 110 stuff in trailer.
Sent from my SM-G965W using Tapatalk
snowtime likes this.
2019 Lima Build
2019 Trailer Build.
Old 10-30-2018, 08:56 PM   #27 (permalink)
calltrex's Avatar
installed the 110 outlet port. the outside half. have to wait till i put walls back up for good to finish inside half.
Got the kit from a local trailer dealer
ID:	2025780   Click image for larger version
ID:	2025786   Click image for larger version
ID:	2025788   Click image for larger version
ID:	2025790   Click image for larger version
2019 Lima Build
2019 Trailer Build.
Old 10-31-2018, 10:38 PM   #28 (permalink)
calltrex's Avatar
started the wiring
adding new wiring for stuff
rewired the whole trailer to my standards.. didnt like how they wired stuff and the stupid push connectors they used
continue tomorrow
ID:	2025922   Click image for larger version
2019 Lima Build
2019 Trailer Build.
Old 11-02-2018, 10:08 PM   #29 (permalink)
calltrex's Avatar
still plugging along with electrical
dont want to forget anything
made an access cover for the trailer wires that come into trailer in case for future
ID:	2026170   Click image for larger version
ID:	2026172   Click image for larger version
ID:	2026174   Click image for larger version
Bontz and tree planter like this.
2019 Lima Build
2019 Trailer Build.
Old 11-04-2018, 01:30 AM   #30 (permalink)
calltrex's Avatar
nice to be putting stuff back together again. front done..
Had my little helper
ID:	2026326   Click image for larger version
2019 Lima Build
2019 Trailer Build.
Similar Threads
WTB - 1979 Blizzard 7500 Project Sled curta3531 Ski Doo Wanted 0 10-10-2018 06:27 PM
Project Assult crdude2 Switchback Assault/RMK (Pro-Ride Chassis) 14 03-12-2018 10:16 AM
Rangeley Airport Extension Project SummitX864 Maine 4 09-09-2017 10:24 PM
Summer project KFS ProCross (2012 - ) 43 08-27-2016 10:22 PM
My Sons Senior Project! Rock On New Hampshire 34 05-10-2016 01:19 PM
