2015 Indy 600 sp questions? - HCS Snowmobile Forums
Indy (Pro-Ride Chassis) This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree1Likes
Old 11-17-2019, 07:39 PM   #1 (permalink)
Newbie
Current Sled(s): 16 600 mxz x, 15 Indy 600 sp
Riding Since: 1968
Default 2015 Indy 600 sp questions?
I havenít had a Polaris since 1997, just purchased this one and performing some prep work, adjusted oil pump and greased everything, vented oil cap, Is there a grease zert behind the secondary clutch on the jack shaft bearing carrier? Do they all puke oil out the ves hose hooked to the solenoid valve?
Johnny Speed is offline   Reply With Quote
Old 11-17-2019, 08:38 PM   #2 (permalink)
Drumerjb's Avatar
Current Sled(s): 14 Indy 800/ 05 800 XC
Previous Sled(s): 72 340 Rupp Nitro,73 440 Nitro,75 440 FA,02 Edge 500
Favorite Riding Area: Any where in WI.
19-20 Mileage:
18-19 Mileage: 1500
17-18 Mileage: 2300
16-17 Mileage: 2100
Riding Since: 1968
No I don't remember a grease fitting I think you have to pop the seal off and add Grease.
Yeah they all push a little bit of oil residue out the solenoid vent tube.
Nice starting point for a sled once you get it set up you'll really like it.
Drumerjb is offline   Reply With Quote
Old 11-17-2019, 08:54 PM   #3 (permalink)
Newbie
Riding Since: 1968
One wire was unplugged from the pipe temperature sensor, any reason someone would disconnect this?
Old 11-17-2019, 10:04 PM   #4 (permalink)
1fastpolaris's Avatar
Current Sled(s): 2020 SBA 850
Previous Sled(s): 12SWB600 09D8 05XC800 00XC500
Favorite Riding Area: UP and N. WI
Riding Since: 1984
not unless they like looking at a check engine light and a crummy running engine. Plug er in!
2019-2020 Polaris Snow Ambassador
Support the sport! Join a club!
I&M Trailblazers Snowmobile Club member
Channahon, IL
1fastpolaris is offline   Reply With Quote
Old 11-17-2019, 10:55 PM   #5 (permalink)
Newbie
Riding Since: 1968
It looks like I could swap this spacer from the inside to the outside where the ski mounts to increase the width of the ski stance?
Old 11-18-2019, 02:51 PM   #6 (permalink)
-dw-'s Avatar
Current Sled(s): 13 Indy, 01 600xcsp, 00 600xcsp
Previous Sled(s): 3 arcticcraps
Favorite Riding Area: from my house
Riding Since: 85
Johnny that spindle bushing is one piece fixed in place.
-dw- is offline   Reply With Quote
Old 11-22-2019, 05:49 AM   #7 (permalink)
Member
Current Sled(s): 13 Indy 600SP, 15 Indy 600, 00 XC500
Previous Sled(s): 06 Fusion 600, 90 Indy 500, 88 Indy Classic (400)
Favorite Riding Area: McGregor, MN
19-20 Mileage: 540
18-19 Mileage: 1500
17-18 Mileage: 900
16-17 Mileage: 600
Riding Since: 2004
I have 2 Indy 600's the only other things I do is run them in Ethanol mode and put cable scratchers on it.
Supposedly Ethanol mode helps engine from running to lean. There is no appreciable performance difference. And the cable scratchers just help if the trail conditions are hard packed to keep it running cooler. My normal temp is right around 123-125 degrees on both machines.
I have blown the bearing behind the secondary on one the machines. The tell tale sign is that the speedometer quits working (just like older machines). Still rode it 15 miles home that way.
c130flyer is offline   Reply With Quote
Old 11-22-2019, 09:37 AM   #8 (permalink)
Lexuslover's Avatar
Current Sled(s): 2012 Switchback Pro R 800
Previous Sled(s): 2001 800XC 1999 XLTSP
bearing is "sealed" from what it says in the service manual. I just take a pick and take the cover off carefully, check it out and pack some low temp grease in there. You shouldn't have to worry to much about this bearing as there isn't a ton of load on it like your driveshaft bearing. Yes, the VES hose pukes
Lexuslover is offline   Reply With Quote
Old 11-22-2019, 10:51 AM   #9 (permalink)
Current Sled(s): 2019 850 Indy
Previous Sled(s): 200 Indy Touring/ Every brand, and some that faded away!
Favorite Riding Area: Northern Ontario, Eastern Mani
19-20 Mileage:
18-19 Mileage: 1400 Miles
17-18 Mileage: 1500 Miles
16-17 Mileage: 2000 Miles
Riding Since: 1967
6000 miles on my 15 SP. Traded in 2 years ago. Still running. Definitely need to vent the oil cap. Lots of ways to do this. I made mine from a one way valve from old Polaris cooling system. No grease nipple behind secondary. Installed new bearing with a needle grease hole. Yes oil comes out the solenoid valve. Don't vent it outside. It freezes up. Just gotta stay on top of the clean up. Installed Skidoo rail mounted ice scratchers for low snow conditions. If you stud it in the middle of the track do not install tunnel protectors. Heat problems. Not needle unless you are using very long studs. Change fuel filter 1500-2000 miles. If it starts plugging you will hear the pump whining. You will love this sled.
Northbushrider is offline   Reply With Quote
Old 11-23-2019, 10:29 AM   #10 (permalink)
Current Sled(s): 2014 Rush Pro
Previous Sled(s): 2014 Sidoo Renegade
Favorite Riding Area: Closest Snow
Riding Since: 1976
I just purchased a 2014 Indy 600 SP w only 800 miles on it for my kid. I planned on adding 1.175" studs? So you say I don't need tunnel protectors?
Jbez is offline   Reply With Quote
