600/800 Indy FAQ, Tips, Tricks, and Mods - HCS Snowmobile Forums
Indy (Pro-Ride Chassis) This is a brand-specific forum. Posts on this forum are assumed to be questions aimed at similar model owners, and are not looking for comments of a sarcastic or "bashing" nature. Please be aware that if you violate this policy you are in danger of losing your posting privileges on this website.The calling out or posting of another members personal information IE phone number or address is prohibited.
Like Tree1Likes
Old 01-07-2015, 10:52 AM   #1 (permalink)
servocam's Avatar
Current Sled(s): Two 2015 Polaris 600 Indy's
Previous Sled(s): 3up Toboggan
Favorite Riding Area: BaaHaHaa-they r lawn ornaments
Riding Since: 2020
Question 600/800 Indy FAQ, Tips, Tricks, and Mods
Welcome to the Polaris 550/600/800/850 Indy Thread
FAQ - Tips - Tricks - Mods
Please contribute by continuing to ask questions and respond to posts in the Indy (Pro-Ride Chassis) - HCS Snowmobile Forums thread. If there is inaccurate information, please post below or send me a PM and advise what is incorrect. If you see topics that need to be added, post or PM.
Please share pics of your ride in the Indy (Pro-Ride) Picture Thread
550 Fan Users go read this: https://www.hardcoresledder.com/foru...liability.html
Table of Contents:
  1. Manufacturer Specs, Manuals and Replacement Parts
  2. Resource Guide - Acronyms, Weights & Measures, Conversions, etc.
  3. Body (Accessories, Bumpers, Hand Guards, Mirrors, Seats, Storage, etc.)
  4. Electrical (DC, Headlight, Instrument Panel, Taillights, etc.)
  5. Engine (Cooling, Exhaust, Fuel, Intake, Oil, etc)
  6. Drive Train (Chain, Clutch, Track)
  7. Suspension (Front & Rear)
  8. Tunnel & Running boards
  9. Maintenance (Pre & Post Season)
Current Snow Coverage
servocam is offline   Reply With Quote
Old 01-07-2015, 10:52 AM   #2 (permalink)
servocam's Avatar
Riding Since: 2020
Default Manufacturer Specs, Manuals and Replacement Parts
Manufacturer Information (Spec Sheet):
550's:
2014
2015
2016
2017
2018
2019
600's
800's / 850's
Manuals - Polaris ATV, Snowmobiles, RANGER, Victory (external link)
Please RTFM
OE Spare or Replacement Parts
Snowmobile Service Parts | Polaris Snowmobiles Store
_
Last edited by servocam; 09-02-2018 at 11:40 AM. Reason: Adding 2019, Updating Links
Old 01-07-2015, 10:53 AM   #3 (permalink)
servocam's Avatar
Riding Since: 2020
Default Resource Guide - Acronyms, Conversions, etc.
Acronyms
  • BFH - Persuasion tool
  • CDI - Common-rail Direct Injection
  • DET - Detonation Elimination Technology
  • FRSS - Front Rear Scissor Stop
  • IFS - Independent Front Suspension
  • MFD - Multi-Function Display
  • OE - Originally Equipped
  • OEM - Original Equipment Manufacturer
  • PERC - Polaris Electric Reverse Control
  • RRSS - Rear Rear Scissor Stop
  • RTFM - Read the F#cking Manual
  • TPS - Throttle Position Sensor
  • WTS - Water Temp Sensor
Weights & Measures
  • Gasoline = ~6.2 lbs/gal (5.8 - 6.6 lbs)
  • Water = ~8.34 lbs/gal
  • Antifreeze = ~9.41 lbs/gal (Polaris Concentrate)
  • VES Synthetic Oil = ~7.25 lbs/gal
  • Polaris Chain Case Oil = 7.13 lbs/gal
Polaris Estimated Dry Weight of 600/800 is 449 lbs (204 kg). Add in weight of the fluids:
  • Gasoline 11.5 gal x 6.2 lb/gal = 71.3 lbs
  • 50/50 Coolant 1.25 gal x ~9 lb/gal = 11.3 lbs
  • Oil 0.95 gal x 7.25 lb/gal = 6.9 lbs
  • Chain Oil 0.07 gal x 7.13 = 0.5 lbs
TOTAL = ~90 lbs fluids + ~449 Sled = ~539 lbs.
Units Conversion
  • 1 inch = 25.4 millimeters | 1 millimeter = 0.039370 inch
  • 1 mile = 1.609 kilometers | 1 kilometer = 0.621371 miles
  • 1 mile per hour = 1.609 kilometers per hour | 1 kilometer per hour = 0.621371 miles per hour
  • 1 gallon = 3.785 liters (=10.6 cold ones) | 1 liter = 0.264172 gallons
  • Square is Square
  • Round is round
  • Ratio of an igloo's circumference to its diameter = Eskimo Pi
  • 1 beard-inch = 29.4 days
  • 1 Donkey Power = 1/3 Horsepower (see Arctic Cat owner for more details)
  • Third Projection Angles:
Old 01-07-2015, 10:53 AM   #4 (permalink)
servocam's Avatar
Riding Since: 2020
Default Body (Accessories, Bumpers, Handle Bars, Hand Guards, Mirrors, Seats, Storage, etc.)
Handle Bars & Risers
Mirrors
Some think they look bad, others think they look great. Either way you look at it, it is all about safety. Do yourself a favor, swallow your pride and put them on. That is your child or best friend behind you! https://www.hardcoresledder.com/forum...0-mirrors.html
Installation Video: http://youtu.be/cRFLyTaVUSw
Note: You cannot have both Mirrors and hand-guards (unless really tall).
Seat
Storage
Windshield
You can go to Polaris.com and "Build" the sled to see what some different styles look like.
_
Old 01-07-2015, 10:53 AM   #5 (permalink)
servocam's Avatar
Riding Since: 2020
Default Electrical (DC, Headlight, Instrument Panel, Taillights, etc.)
12 VOLT AND RCA PLUGS
Polaris Item # 2878475 - 12v accessory plug in 12-volt outlet, great for GPS or phone, dash mount
Polaris Item # 2878227 - RCA adapter (12V power to RCA) allows you to plug in a heated face shield
Polaris Item # 2878780 - RCA Power Plug includes all hardware required to add an RCA outletThe only place you can get 12VDC power is on the 2-pin SAE quick disconnect connector, which can be found under the hood between the headlights.. You can purchase the mating connector at any auto parts store and others (Fleet Farm, Walmart, etc.) for ~$3.
Digital Interactive Display
GPS
Headlight
LED Tail Lights:
Starter - Electric Start:
Tether:
Polaris Item # 2874379 - Predator Tether Switch
Old 01-07-2015, 10:54 AM   #6 (permalink)
servocam's Avatar
Riding Since: 2020
Default Engine (Cooling, Exhaust, Fuel, Intake, Oil, etc)
Air Intake
Antifreeze / Coolant
Break-In Period
First tank with oil added to it (RTFM!). Vary the throttle / Do not cruise at a constant 30mph for the first tank! Don't be afraid to get on it hard for a few seconds at a time. Roller-Coaster the throttle.
https://www.hardcoresledder.com/forum...l#post13612497
Compression Test:
125 psi for 600/800. Results may vary from tester to tester. Cylinders should read the same.
Best practices:
- use a compression tester designed for small engines!
- remove both spark plugs (easier to pull over)
- hold throttle wide open when testing
- be sure key is off and kill switch engaged.
- 3 pulls is all it should take
Cooling / Running Temps
Running 121-125 degrees normal snow conditions. Up to 135 when light loose snow. Hard pack and will push 150 degrees. There are a few things you can do:
  • - Add Ice Scratchers
  • - Snow Flap Extension
  • - Simply drive in loose snow and get on the throttle to kick up some snow!
  • - If you are hitting >150 degrees, then check your coolant system. Burp the system and you may need to check the thermostat. Most likely have air in the system or the thermostat is installed incorrectly (it needs to be orientated correctly).
  • - Intall NORTHSTAR Performacne T-Stat Kit. (See below)
Sources:
Snow Flap Extension:
Scratchers
Dura Flex or Trail Blizzer's
T-Stat Kit:
PM northstarrick for details or look up NORTHSTAR PERFORMANCE N.H. On FACEBOOK. This kit can drop your temps as much as 25 degrees.
Details Post 1 | Details Post 2
Crankshaft
Exhaust
Please keep it quite. 2nd biggest complaint from people is dumbasses that keep BRAP BRAAAPing their loud pipes. (#1 is going off the trails). Keep that Sh!t for your private property & drag strip, and OFF the State/Grant-in-aid trails please.
Source: Local snowmobiling clubs
Threads: Video: 2014 600 INdy MBRP Can
Fuel & Premium vs Ethanol and Settings
RTFM! It's all in there! Do NOT run Ethanol if you can avoid it! If you can afford a snowmobile, you can afford to purchase premium fuel.
Whenever using ethanol, MTBE or other forms of oxygenated gasolines, the fuel type designation setting must be changed to “ETH” in the gauge. When using the recommended 91 non-ethanol gasoline, always select the “91-NON” setting. It is safe and recommended to use Isopropyl with Non-Eth fuel - RTFM!
Threads:
Where to buy Ethanol-Free aka Non-Oxygenated (Non-Oxy) fuel:
DET Mode
Filter
MPG
Horsepower / Torque Rating
We don't exactly know how much power the 600 and 800 have. The 600 is somewhere between 110hp - 125hp and may vary from year-2-year and if you modified the pipe. The 800 is somewhere between 140hp - 150 hp. Google search resulted in some data to make a 600 Chart and 800 Chart.
Threads:
Increasing Horsepower
OIL
VES oil or other IMO, just keep it simple and use the Polaris Engineered VES Synthetic 2-cycle Engine Oil (1 Gallon) - Item #2881017. If you plan to use a different oil, you may need to remove the tank and clean it as not all oils will mix with each other safely.
Threads:
MSDS - Material Safety Data Sheets (PDF's)
Vented Oil Cap
You will find hundreds of threads about the lack of venting the Polaris oil cap
has and how it has damaged engines. Short story - it is cheap to add a vent vs.
new engine. Here are a few to read:Where to buy:
Video on how to bleed: https://youtu.be/mnQ9pVgIvfU
Why to vent: https://youtu.be/7gUJmsw-sVQ
Oil Pump
Programmer / Fuel Controller
Reed Valves
RPMs
Spark Plugs (NGK BPR9ES)
Bontz likes this.
Old 01-07-2015, 10:54 AM   #7 (permalink)
servocam's Avatar
Riding Since: 2020
Default Drive Train (Chain, Clutch, Skid, Track)
Chain Case / Gearing
Chain Case Oil Maintenance (RTFM!)
Thread: https://www.hardcoresledder.com/forum...-600-indy.html
Video: Removing Chain Chase Cover (Thanks ZEG)
Gearing
Threads:
MPH
- MPH based on Gear Ratio, 1:1 Clutch, 9 tooth Drive Sprocket, 2.52 Track Pitch
22:39 = 1.773 (800 OE)......99.9 MPH @ 8,250 RPM
22:40 = 1.818 (600 OE)......97.4 MPH @ 8,250 RPM
22:41 = 1.864...................95.0 MPH @ 8,250 RPM
21:40 = 1.905...................92.9 MPH @ 8,250 RPM
21:41 = 1.952...................90.7 MPH @ 8,250 RPM
(~1.2 MPH per +100 RPM)
Belt
OE: Polaris P/N: 3211115 - BELT-DRIVE,11.5CD,CVT
Spare Belt Holder
Clutch
Threads: Video:
Clutch Kits:
Only one place to go - contact/PM Gabes for his kit.
Max Speed
Slides
Skid
https://www.hardcoresledder.com/forum...d-removal.html
Track
The biggest complaint is the OEM track that comes on the 600 Indy.
  • 600 Indy: 121x15 x 0.91 inch Shockwave
  • 600/800 Indy SP: 121x15x1.0 inch Hacksaw
Composit Talon Tracks:
Overall best improvement sounds to be the Camoplast 1.25" Ripsaw. Even the
reviews think so:
https://www.hardcoresledder.com/forum...s-options.html
BEWARE 1.75" Back Country https://www.hardcoresledder.com/forum...ckcountry.html
Studded Track
https://www.hardcoresledder.com/forum...h-backers.html
Rear Axel
- If you are going to stud your track, you need to add a rear outer wheel idler kit: Rear Outer Wheel Kit | Polaris Snowmobiles Store
Maybe good to put the kit on anyways: https://www.hardcoresledder.com/forum...e-snapped.html
Tunnel Protectors
- required if you stud your track.
Track Tension: (RTFM, Page 98)
Longer Track / Track Extensions
If you want to go longer and turn our Indy in to more like a Crossover (aka
Switchback):
128 Inch: 121" to 128" Extension Package, Package includes Track, Tracks USA
Rail Extensions with hardware to install (No Tunnel Extension needed).
Tracks USA 121" to 128" Track Extension Package from Tracks USA
136 Inch: 121" to 136" Extension Package, Package includes Track, Tracks USA
Rail Extensions and Tunnel Extension with hardware to install.
Tracks USA 121" to 136" Track Extension Package from Tracks USA
144 inch: 121" to 144" Extension Package from Tracks USA
for sale in Lake Lillian, MN | Tracks USA (320) 382-6128
Threads:
Indy Stretched
Old 01-07-2015, 10:54 AM   #8 (permalink)
servocam's Avatar
Riding Since: 2020
Default Suspension and Handling
A-Arms:
Limiter Strap (RTFM!)
Ski's and Carbides
Carbide aka Skags or Wearbars
600 OE PN: 2878820 KIT-SKAG 7/16X4in.60X4 STUD | [PAIR]
600 SP / 800 SP OE PN: 2879025 KIT-SKAG 8MMX4in.60X3 STUD | [PAIR]
Stud Boy Shaper bars are good choice
Shocks
Shock Length (C-C) = 17 3/8"
Torque Arm - Front and Rear
Torsion Spring
Adjusting Torsion Spring (RTFM!)
How to change torsion Spring
Suspension Adjustments
Bunke Racing Kit
Appears to be the ultimate Indy Kit - Polaris Indy Cross Country Racing Kit & Parts
Threads:
_
Old 01-07-2015, 10:55 AM   #9 (permalink)
servocam's Avatar
Riding Since: 2020
Default Tunnel & Running boards
Running Boards
The running boards do not have any holes in them and snow build up makes them slippery. There are a few things you can do:
  1. Drill out from bottom side up. Purchase dimple-die set.
  2. Put on snow cleats
  3. Other
Sources:
Braces
No Snow Brace: https://www.hardcoresledder.com/forum...-supports.html
Contact: fastsleddr
Tunnel Extension & Protectors
See Track for now
Old 01-07-2015, 10:55 AM   #10 (permalink)
servocam's Avatar
Riding Since: 2020
Default Maintenance (Pre & Post-Season)
Pre-Season
The boat is in storage, you just got done watching the grass drags and decide to go picked up your sleds from storage...now what?
Thread: https://www.hardcoresledder.com/forum...dy-season.html (thanks rabbi)
https://www.hardcoresledder.com/forum...ilter-spi.html
More to come / check list.
Also RTFM
Post-Season
Awww maaaaan...the season is over, no snow left to be found. What are the necessary steps to get my sled(s) ready for storage?
Great thread by ZEG that is WAY better than the Extended Storage section when you RTFM (pg ~107).
Threads:
https://www.hardcoresledder.com/forum...ing-video.html
https://www.hardcoresledder.com/forum...g-storage.html
https://www.hardcoresledder.com/forum...l#post14753473
