T Cat & SRX 1" lug track question - HCS Snowmobile Forums
Like Tree13Likes
Old 03-26-2020, 10:59 AM   #1 (permalink)
Member
Default T Cat & SRX 1" lug track question
I am looking to buy a 2019 T Cat but am a 100% trail rider and I see that many who do buy either of these 2 sleds often times put 1 1/4" or taller lug track on them and is it because they just spin way to much or just not good for a trail sled.
I will put a max 17 single tune and a can and a cold air intake on it for sure. I have a 17 cross country 137" 9000 with a 1 1/4" track ( not a 1 3/4") and have 4 studs per bar that Ive had for the last 2 years and did also put Pro4 primary and secondary clutches on it.
I have no problem changing the track and gearing out but was wondering why so many do ??
kdf1157 is offline   Reply With Quote
Old 03-26-2020, 01:02 PM   #2 (permalink)
TMB
TMB's Avatar
Current Sled(s): 2020 Thundercat
Previous Sled(s): all cats
Favorite Riding Area: UP
19-20 Mileage:
18-19 Mileage: 2000
Riding Since: 68
I’m very happy with my 1” track with 144 1.45 triggers on a hard pack trail it hooks up very good. 2 stock turbos mine has 1” ,buddy has 1.25 ,maybe it’s the gears but mine pulls him in all trail conditions.in the end does a 1/4” make that much difference?
Boom2 likes this.
TMB is offline   Reply With Quote
Old 03-26-2020, 01:40 PM   #3 (permalink)
Turboflash's Avatar
Current Sled(s): 2017 ZR9000 Ltd
Previous Sled(s): ZR900, ZR800, ZR700, etc - all improved stock or more
Favorite Riding Area: northern WI
19-20 Mileage:
18-19 Mileage: 1800
17-18 Mileage: 1700
16-17 Mileage: 1859
Riding Since: 1968
Yes, 1" will spin too much in trail IMO. Cat did it to increase top speed NOT because it was better all around. Most guys say a 1" track for normal hard-pack trail riding is worthless. 1-1/4" much better. I suppose you can nullify some of the effects of having a 1" track by adding lots of studs. Still not same as having 1.25" track if riding in loose or deeper snow as the studs don't help much at all in that condition.
gearhead likes this.
'17 ZR9000 Ltd
Turboflash is offline   Reply With Quote
Old 03-26-2020, 01:51 PM   #4 (permalink)
rockerdan's Avatar
Current Sled(s): 850 XRS 129"
Previous Sled(s): '18 Sidewinder RTX,'16 1200X,'14 Doo 800X,'12 Cat Turbo,Apex
Favorite Riding Area: Val-d'Or,Amos,Rouyn Qc,Muskoka
Riding Since: 1970
Also remember the new '21 Tcat now comes with a 1.25 track, so the SRX is now in its own class of top speed category. I prefer the 1.25" track for every application with exception of speed runs/radar guys.
Dan
'18 50th RTX LE Winder
My 998 Build Thread:
rockerdan is offline   Reply With Quote
Old 03-26-2020, 06:33 PM   #5 (permalink)
Turboflash's Avatar
19-20 Mileage:
18-19 Mileage: 1800
17-18 Mileage: 1700
16-17 Mileage: 1859
Riding Since: 1968
Agree, AND speed run/radar guys are usually running on ice or something close to it and usually have studs to penetrate surface. They usually aren't running on loose or semi-packed trail snow where higher profile tracks are better.
IMO, 1" track on a true trail sled to me is pretty worthless.
rockerdan likes this.
'17 ZR9000 Ltd
Old 03-26-2020, 06:43 PM   #6 (permalink)
TommCat Performance
Tommcat's Avatar
Current Sled(s): too many
Favorite Riding Area: Maine
Riding Since: 1977
Because people that shouldn't buy a thundercat, bought a thundercat.
The Tcat should absolutely have a 1 inch speed track in it, as well as a lower ride height.
It should have also come with a higher gear ratio imo.
The regular ZR should be aimed at trail riders and have a 1.25
Sent from my SM-J737V using Tapatalk
Old 03-26-2020, 07:01 PM   #7 (permalink)
31cccat's Avatar
Current Sled(s): 19 TCAT
Previous Sled(s): Turbos
I prefer the 1 inch.
The tcat or srx handles better
We have a 17 Ltd and 18 Thundercat and anyone that gets on my 19 tcat says it handles way better than previous two.
It’s lowered. It high speed corners better
I have had both and my 1 inch is better handling and hooking than the 1.25 where I ride.
I also run studs 1/2 past lug on it too and they have been great.
Angled backers. 128 studs
It hooks pretty well on everything
cropsprayer likes this.
31cccat is offline   Reply With Quote
Old 03-26-2020, 10:42 PM   #8 (permalink)
Current Sled(s): 2017 ZR 6000 RS, 2016 ZR 4000 RR
Previous Sled(s): 2011 1200, Mxz 1200, Nytro XTX, Apex, Rev 800, ZR 800, etc..
Favorite Riding Area: Where the snow is
Riding Since: 10
I wonder why Cat switched back? Because in 17 and 18's they were 1.25. Then in 19 they lowered the sled and went to 1". In 2020, the sled is still lowered, new front end and tweaks to the rear and still a 1". Now for 2021, they go back to the 1.25". I am wondering because of the lowered front end, that maybe they seen a better gain bottom and mid with a slight decrease in top end because of the sled being lowered? Not as much of a loss compared to 17-18 to a 19-20? I have been trying to find a solid answer and I cant.
agentzoey is offline   Reply With Quote
Old 03-26-2020, 10:55 PM   #9 (permalink)
snappydave's Avatar
Current Sled(s): '15 ZR9000LTD and '15 XF9000LTD
Previous Sled(s): '07 F1000S/P,'07 Z1
Favorite Riding Area: HoughtonLake,Caddy, Raco,Seney
19-20 Mileage:
18-19 Mileage: 1200
17-18 Mileage: 800
16-17 Mileage: 350
Riding Since: 1968
I had a '12 Turbo with a 1" studded Hacksaw, and I loved the way it ran, rode and handled. It had taller gears & TD boosted,, stupid fast.
TMB likes this.
"He who dies with the most toys,,still dies."
snappydave is offline   Reply With Quote
Old 03-27-2020, 07:17 AM   #10 (permalink)
TommCat Performance
Tommcat's Avatar
Riding Since: 1977
They switched because the people that bought them, whined about the track.
remo1356 likes this.
