New wiring loom problem - HCS Snowmobile Forums
Old 03-22-2020, 05:34 PM   #1 (permalink)
tcatinc1's Avatar
Default New wiring loom problem
I have 2016 zr 9000 turbo. I put a new wiring loom in and when I tried to start it the gauge, break light and ignition are that works. The head light , knock light and fuel pumps are not working. I checked the power at the fuse box and it is there. I have also checked the fuses etc. And ideas before I rip this apart again??
tcatinc1 is offline   Reply With Quote
Old 03-22-2020, 10:53 PM   #2 (permalink)
pmk
pmk's Avatar
Current Sled(s): 2017 ZR9000
Previous Sled(s): 2012 F8 SP
19-20 Mileage:
18-19 Mileage: 2500
16-17 Mileage: 2000
Riding Since: 1971
Maybe if the loom is too tight or putting pressure on the wires the pins in the plugs are being pulled and losing contact. I've seen that happen when wiring harnesses are too short.
Long may you run....
pmk is online now   Reply With Quote
Old 03-25-2020, 07:16 AM   #3 (permalink)
04redsnopro's Avatar
Current Sled(s): 17 ZR9000
Previous Sled(s): 15XF800,13 800RR,04F7, 04/5 revs, 99zr600, others..
Favorite Riding Area: UP, &oceana co. area
19-20 Mileage:
18-19 Mileage: 1600
17-18 Mileage: 1450
16-17 Mileage: 600
Riding Since: 1972
you installed a complete new harness? or just added or replaced the plastic loom that protects the wire harness? Check for power and ground at the fuel pump yet?
04redsnopro is offline   Reply With Quote
Old 03-25-2020, 03:26 PM   #4 (permalink)
tcatinc1's Avatar
I replaced the entire loom and checked the fuel pumps also rechecked the TD switch connections as well as the loom ground. I changed the plugs,coils and still wont start on it's own.
Old 03-25-2020, 05:34 PM   #5 (permalink)
Current Sled(s): 2013 xf 1100 turbo snopro
Previous Sled(s): all doo's
Favorite Riding Area: manitoba
Riding Since: 1973
Do you have your old harness, can you compare the 2 of them side by side, plugs, pins, wires, etc etc.
c206a is offline   Reply With Quote
Old 03-25-2020, 08:25 PM   #6 (permalink)
tcatinc1's Avatar
Ya. I do have the old loom. I did put them side by side. I am starting to think an injector is bad. Because it starts and sounds terrible and than shuts down. I put a new regulator on and ave good pressure. Also checked the fuel lines. I shimed the valves as well. I don't know were to look next.
Old 03-26-2020, 01:05 AM   #7 (permalink)
Riding Since: 1973
When i had my engine out last summer, and put it back in, first fired it up it ran real bad, then found one of the injector plugs wasn't quite all the way pushed on tight.
