'16 ZR handlebars slipping and shock upgrade - HCS Snowmobile Forums
Like Tree4Likes
Old 09-12-2019, 12:04 AM   #1 (permalink)
carkhz316's Avatar
Current Sled(s): '16 ZR9000
Previous Sled(s): 12 F8SP, 02 ZR8, 95 ZR7, 93 EXT 550, 92 Jag 440, 76 Cheetah
Favorite Riding Area: In snow
19-20 Mileage: Ha,
18-19 Mileage: If we
17-18 Mileage: Ever got
16-17 Mileage: Snow
Riding Since: 1986
Default '16 ZR handlebars slipping and shock upgrade
Hey HCS, hope everyone's summer is going well. I have two questions:
My bars periodically slip/ fold downwards/ towards me when riding hard and pulling on the bars. I have the riser (stock 4.5") bolts tightened as much as I dare, but it still slips once in awhile (at the base of the riser where it meets the steering post). Does anyone have a tips to make it rock solid and stop slipping?
Also, I have searched in the past but have found a myriad of suggestions regarding what to do with the non-QS3 center shock. I'd like to upgrade it to perform better or on par with the rest of the QS3s. Any and all suggestions welcomed. Thanks!
Just here for the pizza
carkhz316 is offline   Reply With Quote
Old 09-12-2019, 07:23 AM   #2 (permalink)
Rubrsidedown's Avatar
Current Sled(s): 17 XFXC 9k LTD and a 14 ZR 7k LTD
Previous Sled(s): Many (all Cats)
19-20 Mileage:
18-19 Mileage: 3418
17-18 Mileage: 3189
16-17 Mileage: 3287
Riding Since: 70s
I would say the bolt aren't tight enough on the riser, both upper and lower... All 8 bolts need to be very tight.
Sent via my US Cellular rotary dial device.
Jeff B In Maine
Rubrsidedown is offline   Reply With Quote
Old 09-12-2019, 10:06 AM   #3 (permalink)
Super Moderator
Jester's Avatar
Current Sled(s): 17 Sidewinder LTX-SE, 12 f1100lxr
Previous Sled(s): 12 F 1100 SP Turbo06 cf 700 SP, 05 F7sp, 08 f1000, 07 cf1000
Favorite Riding Area: Norther Ontario/ Quebec
19-20 Mileage:
18-19 Mileage: 2200
16-17 Mileage: 800
Riding Since: 1969
On the shocks, order the aftermarket spring from the Yamaha site that is availble for the sidewinder. It makes a world of difference. I will see what I can do to get you some contact information.
Jester
Ready for snow wherever it may be!!!!
Jester is offline   Reply With Quote
Old 09-12-2019, 01:34 PM   #4 (permalink)
nosajlleb's Avatar
Current Sled(s): Cataha 998T Cross Country
Previous Sled(s): 14 Proclimb12 M1100T 153,97 zrt600, 01 mc600, 07 xfire1000sp
Favorite Riding Area: U.P.
19-20 Mileage:
18-19 Mileage: 2000
17-18 Mileage: 1200
16-17 Mileage: 2000+
Riding Since: 1981
Jester
A thousand times order that spring! I have one and it is undeniably needed. The stock one is a Textron special, they just kept it the same as the lighter 800 version.
nosajlleb is offline   Reply With Quote
Old 09-12-2019, 02:42 PM   #5 (permalink)
Is that shock something recommended for the 2 strokes also or just with the heavier 4 strokes?
I saw this thread and it reminded me that someone I ride with lost 2 of those handlebar bolts last year, so good idea to keep eye on them. Ended up riding with 3 and 3 until we found a hardware store.
HoosierFusion is offline   Reply With Quote
Old 09-12-2019, 06:59 PM   #6 (permalink)
19-20 Mileage:
18-19 Mileage: 3418
17-18 Mileage: 3189
16-17 Mileage: 3287
Riding Since: 70s
Not a bad idea to use a little blue loc-tite on the bolts.
Jeff B In Maine
Old 09-12-2019, 07:45 PM   #7 (permalink)
carkhz316's Avatar
19-20 Mileage: Ha,
16-17 Mileage: Snow
Riding Since: 1986
I'll will definitely be ordering that spring. Also, I use blue threadlock almost everywhere on my sled. The problem isn't that the bolts have loosened, but are just not clamping tightly enough. They feel like they are going to strip the threads in the aluminum riser block.
Old 09-12-2019, 08:59 PM   #8 (permalink)
Turboflash's Avatar
Current Sled(s): 2017 ZR9000 Ltd
Previous Sled(s): ZR900, ZR800, ZR700, etc - all improved stock or more
Favorite Riding Area: northern WI
19-20 Mileage:
18-19 Mileage: 1800
17-18 Mileage: 1700
16-17 Mileage: 1859
Riding Since: 1968
Are the two sides touching each other when you tighten the bolts? If so, an easy fix might be to take .010 - .020" off one side of the clamp. If they are not touching each other, you're gonna have to create more friction between the handlebars and the risers somehow. Create some serrations on both. Multiple ways to do that. A good sharpened chisel could create "grooves" (aka serrations) on either (I would do both) if done properly. Then, use some kind of Loctite when you're putting them together. Clean both parts well and use retaining type Loctite.
snowcrazy1 likes this.
'17 ZR9000 Ltd
Turboflash is online now   Reply With Quote
Old 09-12-2019, 09:16 PM   #9 (permalink)
snowcrazy1's Avatar
Current Sled(s): 2016 ZR 6000 LTD
Previous Sled(s): 98 srx700
Favorite Riding Area: lost pines lodge
or make notch's with dremel tool after surfacing hold down cap's pretty sure front bolts tighten till cap's touch then tighten rear then all to spec, whatever that is. to lazy to look in shop manual .
snowcrazy1 is offline   Reply With Quote
Old 09-13-2019, 11:18 AM   #10 (permalink)
carkhz316's Avatar
19-20 Mileage: Ha,
16-17 Mileage: Snow
Riding Since: 1986
No, the caps aren't touching the riser block when fully tightened. I think I will do what you guys suggest and notch the bars where the block mounts to give it some bite.
Regarding the Yam spring: is that a stock part or does anyone have a link on where/ what to purchase?
