T-Cat stud length - HCS Snowmobile Forums
Like Tree1Likes
  • 1 Post By KnappAttack
Old 05-11-2019, 08:11 AM   #1 (permalink)
MR WEEZ's Avatar
Current Sled(s): 18' Sidewinder LTX LE
Previous Sled(s): 15 Yami's 3 Doo's
Favorite Riding Area: Northern ON & Da UP Eh
18-19 Mileage 4095 km's
17-18 Mileage: 4430 km's
16-17 Mileage: 3786 km's
15-16 Mileage: 2990 km's
Riding Since: Lad
Default T-Cat stud length
What are you guys using for length on your 1.25" tracks? The reason I ask is I just put a tune on my sled and don't want to add more studs but want to go with a longer stud than my current 1.4's.
MR WEEZ is offline   Reply With Quote
Old 05-11-2019, 08:26 AM   #2 (permalink)
erskin's Avatar
Current Sled(s): 2018 THUNDERCAT
Previous Sled(s): 14 XF9000 LTD, 12 XF1100 TURBO LXR 07 F1000
Favorite Riding Area: Northern Maine
18-19 Mileage 2260
17-18 Mileage: 1340
16-17 Mileage: 1350
15-16 Mileage: 250
Riding Since: 1978
I run the woodys 1.325, 144 down the middle all on double backers. I personally feel the double backer setup hooks much better than singles and the strength is exceptional. I have had 3 boosted cats and did same with all. Hooked great on trail and never bent any. This is what I run currently on my 18 tcat boosted at 270 and found it to hook very well, no complaints. I don't know how many studs you're running currently or where they are placed but I would say try it first before you make any changes..
erskin is offline   Reply With Quote
Old 05-11-2019, 08:48 AM   #3 (permalink)
MR WEEZ's Avatar
Riding Since: Lad
My set up with 144 at 1.4 length. I figure running a 270 tune a little extra bite will be needed.
Old 05-11-2019, 09:02 AM   #4 (permalink)
erskin's Avatar
18-19 Mileage 2260
17-18 Mileage: 1340
16-17 Mileage: 1350
15-16 Mileage: 250
Riding Since: 1978
I wouldn't change a thing personally, try it as is. This is assuming you run mainly good hard pack trails or rail beds most of the time. I personally find the sled handles a bit better with this amount of studs, you can get a slight kick of the ass end on corners. Also, these are already light up front on skis so adding more studs you're probably going to see more push by adding studs.
Old 05-11-2019, 10:23 AM   #5 (permalink)
KnappAttack's Avatar
Current Sled(s): 2017 Yamaha Sidewinder LTX-LE
Previous Sled(s): Many! The latest 2014 Doo/Turbo XR1200
Favorite Riding Area: UP of MI, North MN
Riding Since: 1972
I'd run it first too.
Long studs just flex and loose traction anyway. I've never been a believer in long studs or too many studs for that matter either.
I run 192 1.45" Megabites mostly in double backers and feel its too many on a trail sled with the Rip2 1.25". I've been thinking about removing some from the outside belt even running the big tunes. What I have now actually hooks too good.
Traction lines and placement is the more important than qty or length.
Kangas Motorsports likes this.
KnappAttack is offline   Reply With Quote
Old 05-11-2019, 08:48 PM   #6 (permalink)
Current Sled(s): Sidewinder RTX Le
Previous Sled(s): Nytro
Favorite Riding Area: District 8
18-19 Mileage 5000km
16-17 Mileage: 3000
15-16 Mileage: 3500km
1.575 Megabite works well. I would say the most durable and the longest you would want to go for trail riding. Also, anything longer than about 9/16th above the lug you need after market tunnel protection. 1.575 woodies is exactly 9/16th penetration. I am not sure about the other stud brands.
Just a heads up if you haven't ridden with long studs like that, it will hook better in a straight line, but you will lose the ability to kick the rear end out in turns and slide the sled around. I am torn between running longer vs shorter studs in my sled. It is more fun to ride aggressively, IMO, with the shorter studs, using the throttle input to steer the sled. But my sled with the 1.575s hooks so nice in a straight line. Everything is a compromise right.
big_phil is offline   Reply With Quote
Old 05-11-2019, 09:29 PM   #7 (permalink)
Turboflash's Avatar
Current Sled(s): 2017 ZR9000 Ltd
Previous Sled(s): ZR900, ZR800, ZR700, etc - all improved stock or more
Favorite Riding Area: northern WI
18-19 Mileage 1800
17-18 Mileage: 1700
16-17 Mileage: 1859
15-16 Mileage: 2100
Riding Since: 1968
280HP tune. I run 192 studs all in center belt. 1.25" RipSaw 2. Double Stud Boy ProLite backers with 1.630" Stud Boy Lake Racer carbide studs. They've never hit anything in tunnel. No protectors. Run track the correct tension and they won't hit.
2017 ZR9000 LTD Stage 3 (280 HP) Precision EFI. TurboSmart BOV, 2.5" D&D stainless exhaust, head studs, 21/38 gear, 192 ea Studboy 1.63" Lake Racer studs on StudBoy double ProLite backers.
Turboflash is offline   Reply With Quote
Similar Threads
Stud length for 1" lug on 02 700 xcsp petermb72 XC 5 10-22-2018 06:58 PM
woodys stud length albee Indy (AXYS Platform) 58 04-26-2018 12:27 PM
Question about stud length unlimited Turbo 4 Stroke 20 11-26-2017 10:18 PM
Max Safe Stud Length With Cat Protectors snave8 Turbo 4 Stroke 4 11-13-2017 06:53 PM
New Ripsaw 15 X 1.5 x 128" Max Stud Length pantera tank ProCross (2012 - ) 5 01-06-2017 05:47 PM
