2019 IAct Issues!! - HCS Snowmobile Forums
Like Tree6Likes
Old 02-22-2019, 12:22 PM   #1 (permalink)
Member
Default 2019 IAct Issues!!
Hey all,
Just wondering if anybody has been having a hard time with their IACT.
I have had 2 sleds with the IACT and both have shown codes.
Sled #1: C1525 and C1526
Sled #2: C1523 with 40 miles
Spoke to all dealerships around me and they have all told me that they have not had any issues at all. Also told me that "C" codes are not arctic cat, even though I'm pretty sure that 2019 Thundercat is an Arctic Cat.
If you've had these codes, please let me know if/how it was fixed.
Crushed It is offline   Reply With Quote
Old 02-22-2019, 05:18 PM   #2 (permalink)
Cruisin Home's Avatar
Current Sled(s): Arctic Cat 2018 ZR9000 Sno Pro, 2019 ZR9000
Previous Sled(s): various Arctic Cats, 1st sled in 70's = Rupp 440Nitro
Riding Since: 1969
I am at 430 miles on a 2019 IACT. No problems yet.
Are you just getting the codes, or is it also having some symptoms?
Cruisin Home is offline   Reply With Quote
Old 02-22-2019, 06:02 PM   #3 (permalink)
31cccat's Avatar
Current Sled(s): 19 TCAT
Previous Sled(s): Turbos
I have 1600 on tcat and not an issue
31cccat is offline   Reply With Quote
Old 02-22-2019, 09:08 PM   #4 (permalink)
Member
No symptoms, code and it defaults to super stiff. Went riding last night and trails were tabletop. Would have loved to have been able to flick it to soft and rip. Just not the same on stiff...
Pretty frustrated that all dealers say they haven't had issues but I have had 2 sleds in 2 months and they both have had issues..
Old 02-22-2019, 09:12 PM   #5 (permalink)
Fun11cat's Avatar
Current Sled(s): 2020 ZR 8000 LTD IACT
Previous Sled(s): 14 XF 7000 10 F8 SP,05 F6,02 ZL 600SS, 99 ZL 600, 96 Pantera
Favorite Riding Area: Central MN
19-20 Mileage: 1425
18-19 Mileage: 1170
17-18 Mileage: 1260
16-17 Mileage: 960
Riding Since: 1972
Maybe try a get in contact with area cat factory rep or cat them self's in Thief River.
Fun11cat is offline   Reply With Quote
Old 02-22-2019, 09:30 PM   #6 (permalink)
cfm
Current Sled(s): 900 Fuse-10,800miles and going / 06 600HO M10
Riding Since: 3 BC
Maybe look in the Service Manual ?
https://support.countrycat.com/posts...service-manual
PPP Charter Member #2
Old 02-23-2019, 08:26 AM   #7 (permalink)
Lovethoseoldcats's Avatar
Current Sled(s): 2019 ZR 8000 LTD iACT 137
Previous Sled(s): 14 XF 8000, and many other cats
Favorite Riding Area: Anywhere there is snow.
19-20 Mileage:
18-19 Mileage: 1700
17-18 Mileage: Never enough
16-17 Mileage: 1200
I have the 2019 ZR 8000 Limited with iAct and had a problem. The right shock would not adjust to the Firm position. Could not tell if all shocks actually adjusted between Soft or Medium. I did not get any codes on the display. Took to dealer. They checked it out and found codes c1523, c1524, c1525, & c1526. They called Cat. The tech, at Cat, told them to replace the shock. Appears to be working now. Again, I did not get any codes on the display like you have. The dealer found the codes. Not sure if this helps or not. Do your shocks actually change? When I first got my sled I could not tell much of any difference in the settings while riding. While stationary I found out mine was not working by changing the settings and rocking the sled back and forth after each setting. I could tell that the rear shock was changing and possibly the left shock too but the right shock would still bounce on the Firm setting. After the dealer replaced the right shock, and rocking the sled on the Firm setting, the sled is rock solid now all around.
I have no idea what these codes mean but they have something to do with the shocks not changing even though the display says they are. I do not know why my display did not show these codes and yours does. The dealer must have found them by hooking it up to the computer.
Frozenstiff likes this.
Lovethoseoldcats is offline   Reply With Quote
Old 02-24-2019, 10:23 PM   #8 (permalink)
Member
I have talked to a few different dealerships and they have all told me that I need to tae the sled in.
I will be bringing it in in the net week to get looked at. Just frustrating that I will likely have to be without my sled for over a week. I typically go 1-2 times per week, and this winter has been FANTASTIC!!
If anyone else has had issues, please share for information.
Old 02-24-2019, 10:28 PM   #9 (permalink)
31cccat's Avatar
Check your connections just to see if there is a loose wire in one of the plugs(one pulled out enough to have poor connection)and also check to see if a wire is rubbed through. Rear skid has an outer and an inner wire holder by chaincase. I put my sled together and made sure everything was clear from wires rubbing anything and that they didn’t have tension on wires.
Old 02-25-2019, 11:39 AM   #10 (permalink)
rlh6805's Avatar
Current Sled(s): 2013 F1100 Turbo Sno Pro Limited
Previous Sled(s): 10 Z1 Turbo; 06 Firecat 500
Favorite Riding Area: Northern MI
Riding Since: 1990
IMO, I think everyone should of seen this coming. This electric remote adjust system is is not conducive to the environment in which these things are used. Problems are only going to increase as time in service goes by.
Rob
rlh6805 is online now   Reply With Quote
Similar Threads
2019 AC Thundercat IACT 31cccat Arctic Cat 4 02-02-2019 11:54 AM
2019 TCat with iAct eastmark Turbo 4 Stroke 3 01-30-2019 09:38 PM
2019 Arctic Cat IACT suspension a gamechanger!!! Cruisin Home Arctic Cat General Discussion 1 12-17-2018 03:01 PM
I demo rode the 2019 Snowmobiles Trail Ryder General Snowmobile Forum 98 03-20-2018 09:32 AM
2017 TEAM Secondary Issues After Turning Up esabo Turbo 4 Stroke 12 01-24-2018 09:57 PM
