Poor Idle. - HCS Snowmobile Forums
Like Tree4Likes
Old 04-15-2018, 08:33 PM   #1 (permalink)
Auglen's Avatar
Current Sled(s): Z1 Turbo EXT, Renegade 1200 1980 Enticer 340T
Previous Sled(s): 2007 Apex, 2000 Pantera 2UP
18-19 Mileage 1500
Default Poor Idle.
All winter I've noticed my sled getting progressively worse in regards to cold start idle. The sled has performed well otherwise. Upon startup I'm running on one cylinder for up to 15 long seconds before it fires on both. Idles up to 1700. Then when it reaches operating temp it idles 1200 to almost stalling. (Belt on or off). I will help it with some throttle and spin the track to warm things up. Then it picks up rpm and all ok. After riding and stopping for a break. When I start it again, it fires up great but idles low 1200 to 1300. I feather the throttle to 2500 for a few seconds and then it picks up idle and all good.
Sled has 8000 miles on it. Valves were checked at 5400 miles. Had stock plugs gapped to 20 at the time. I have run a FTS single flash and Sandale max flow muffler for 3 years. The idle stop screw was adjusted when I had the flash installed. It was suggested to tweek it to idle around 1800.
I did tweek it slightly this winter to try to alleviate the low idle isue. I know that is not going to solve the problem. Its a Z1 Turbo EXT by the way.
I was thinking maybe the IAC or dirty throttle body or maybe valve check again? Anybody experience similiar issues? Thanks
Boom2 likes this.
Auglen is offline   Reply With Quote
Old 04-15-2018, 08:44 PM   #2 (permalink)
jeffh62's Avatar
Current Sled(s): 2015 F1100T LXR
Previous Sled(s): 2012 F1100T, 2010 800cfr, 2003 F7
Could be the things you mention, but I would change plugs as a start
jeffh62 is offline   Reply With Quote
Old 04-15-2018, 09:14 PM   #3 (permalink)
ness t nitro's Avatar
Current Sled(s): 2010 Z1 Turbo SnoPro
Previous Sled(s): TNT f/a, Invader, RXL, Ultra SPX, 05 F7 Firecat
18-19 Mileage 2300
16-17 Mileage: 1200
15-16 Mileage: 900
Riding Since: 1968
A tired battery will do that to you also. Make sure it's fully charged. Easy thing to check before you start tearing half the sled apart. If you going for the plugs you may as well go that little bit further and clean the IAC.
Breakin and fixin sleds since 1969.
ness t nitro is offline   Reply With Quote
Old 04-15-2018, 09:22 PM   #4 (permalink)
Auglen's Avatar
18-19 Mileage 1500
Battery is old. Could be original cat battery. Gauge was showing 14.3v at idle.
Old 04-16-2018, 10:32 AM   #5 (permalink)
canoehead's Avatar
Current Sled(s): 2014 XF 9000 HC Limited
Previous Sled(s): 440 Motoski,340 Scorpion,JDX8,440Prowler,700ZR,RX1, 09 Nytro
18-19 Mileage 2400
15-16 Mileage: 800
Riding Since: 1967
I've got the FTS single stage flash and noticed the same thing this year even more than last. It appears on cold starts my engine surges from 1200 to 1650 until warmed right up. Then good consistent idle. Sometimes I think it's going to stall out. Hope it doesn't get worse next year. I did mention it to Steve when I had my flash initially done but he just kinda went hmmm strange.
All the oil might be in Alberta but the dipsticks are in Ottawa.
canoehead is offline   Reply With Quote
Old 04-16-2018, 05:32 PM   #6 (permalink)
One ft tune I rode with did same thing. Crappy idle. Grab a stock ecu and try.
Zrboy8 is offline   Reply With Quote
Old 04-17-2018, 04:21 AM   #7 (permalink)
gearhead's Avatar
Current Sled(s): 2015 XF9000 Ltd 2012 F1100 Turbo 2010 F8
Previous Sled(s): F1000 LXR XP 800 F7 ZR900 Mach Z
Favorite Riding Area: Yellowstone Quebec Sask
18-19 Mileage 1000
17-18 Mileage: 700
16-17 Mileage: 1100
15-16 Mileage: 600
Riding Since: 1966
Who does the FTS flash?
Never argue with an idiot, he will drag you down to his level and then defeat you with experience.
gearhead is offline   Reply With Quote
Old 04-17-2018, 12:39 PM   #8 (permalink)
Auglen's Avatar
18-19 Mileage 1500
Full Throttle Speed. Got my flash from Mike at Sandale. Grand Pointe Winnipeg MB
Old 04-17-2018, 12:56 PM   #9 (permalink)
canoehead's Avatar
18-19 Mileage 2400
15-16 Mileage: 800
Riding Since: 1967
Ditto here.
Old 04-17-2018, 06:02 PM   #10 (permalink)
Rebmo's Avatar
Current Sled(s): 2015 AC XF9000 & VIPER R-TX-DX
Favorite Riding Area: Western U.P. & Keweenaw
After installing TD et/pt my idle was all over and died or dropped really low and slowly came back to under 1500. Thought it was the tune. Ben @TD advised cleaning IAC and it returned my idle to perfect. Sage advice.
2015 XF9000 SNP LTD, SLP Mohawk Skis, Mid shield W/Mirrors, JT 4 wheel kit, 2 Stage TD ET/PT, TD Stock Exhaust Mod, Evolution Powersports Blow off Valve, Ski-Doo Scratchers, Mountain Addiction 3.3Gal fuel Caddy, Skinz Knee pads, 509 Delta R3 2.0 Helmet, RR Axle shafts, HyGear Dual Pressure Kit for front Fox floats, Cyclops LED Lighting, Dalton primary weights.
Rebmo is offline   Reply With Quote
