Vibration question - HCS Snowmobile Forums
Like Tree1Likes
Old 02-19-2018, 09:22 AM   #1 (permalink)
Katch_me's Avatar
Current Sled(s): '13 F1100 Turbo X2, '86 Yamaha SRV, 76' Merc
Previous Sled(s): 1976 El Tigre 5000, 1978 Jag 4000, 1993 Jag 440, 1995 VMAX 5
Default Vibration question
I picked up a modded 13' turbo. On my first ride I noticed a slight vibration on the foot boards. And I little more on the left foot. Yes, I know, could be the drive bearings. I changed the jack shaft bearings and checked the track bearings. All good. The only reason I didn't look at the drive shaft bearings is because the previous owner recently installed an anti ratcheting drive and said the bearings were good.
So my question... I feel the vibration might be from my loud 3" exhaust OR from my anti ratcheting drives. Anyone have experience with this??
I sort of felt the vibration more when I was revving it up, louder exhaust. But when I do that I am also driving faster. And I was thinking that the anti ratcheting drives must cause more friction at the track and could cause a vibration.
Thanks in advance for all the suggestions!
Katch_me is offline   Reply With Quote
Old 02-19-2018, 09:28 AM   #2 (permalink)
RW68CAMARO's Avatar
Current Sled(s): 2017 zr 9000
Previous Sled(s): 2012 Turbo Retro 2012 F8 Retro - And many TCATS
Favorite Riding Area: hardpack flat top
check your drive belt to see if there is a burn mark in it, that will cause a driveline vibration for sure. RW
ghost rider likes this.
Ron Ward Racing - Hi-Tech Mechanical & Coatings
Developer of the Twister and Tornado Torsional conversions for 2012-2017 Arctic Cat Snowmobiles!
In-House Engine Alignment complete with bump stop and adjustable poly engine mounts!
Distributor of All things Turbo Dynamics and Sandale Exhaust!
902-883-8677
RW68CAMARO is offline   Reply With Quote
Old 02-19-2018, 09:54 AM   #3 (permalink)
snappydave's Avatar
Current Sled(s): '15 ZR9000LTD and '15 XF9000LTD
Previous Sled(s): '07 F1000S/P,'07 Z1
Favorite Riding Area: HoughtonLake,Caddy, Raco,Seney
19-20 Mileage:
18-19 Mileage: 1200
17-18 Mileage: 800
16-17 Mileage: 350
Riding Since: 1968
Check the placement of the studs in your track, may be under the idler wheels. Also, retorque the studs to make sure the heads are pulled down as flush as possible. snap
"He who dies with the most toys,,still dies."
snappydave is offline   Reply With Quote
Old 02-19-2018, 11:56 AM   #4 (permalink)
Twinrats496's Avatar
Current Sled(s): 12 XF 1100 Turbo
Previous Sled(s): 04 ZR900, 98 ZRT w/1000D&D, 93 T-Cat, 86 600 Indy w/707 SLP,
Favorite Riding Area: U.P.
19-20 Mileage:
18-19 Mileage: 1500
16-17 Mileage: 1900
Riding Since: 1964
Worn out secondary can cause vibration you can feel in your feet.
Twinrats496 is offline   Reply With Quote
Old 02-19-2018, 03:14 PM   #5 (permalink)
Current Sled(s): '17 9000 shorty/Poo 850
Previous Sled(s): '16 ZR9 '15 XRS8, '13 Turbo, '12 XRS 8, '05&07 Mach Z
Favorite Riding Area: Anywhere in the U.P.
19-20 Mileage:
18-19 Mileage: TBD
17-18 Mileage: 2500
16-17 Mileage: 2800
Riding Since: 1975
2nd that worn secondary (STM's tuner's were rather quickly if you have one of those)
Also bent drive shaft OR dented/deflected drivers from hitting a rock just right
tcat100 is offline   Reply With Quote
Old 02-19-2018, 03:17 PM   #6 (permalink)
canoehead's Avatar
Current Sled(s): 2014 XF 9000 HC Limited
Previous Sled(s): 440 Motoski,340 Scorpion,JDX8,440Prowler,700ZR,RX1, 09 Nytro
19-20 Mileage:
18-19 Mileage: 2400
Riding Since: 1967
A couple of questions.
1) What's on it for a track?
2) Does it happen right away or after a short ride?
All the oil might be in Alberta but the dipsticks are in Ottawa.
canoehead is offline   Reply With Quote
Old 02-19-2018, 04:37 PM   #7 (permalink)
Katch_me's Avatar
I didn’t think about that. I don’t have the sled now to check. I do know that the track was replaced last year. I don’t know what kind of track. I noticed that under the idler wheels are bumps/ridges in the track. Not like the stock track. That could explain what you are talking about
Old 02-19-2018, 04:39 PM   #8 (permalink)
Katch_me's Avatar
The secondary seems fine. Although a couple of fins on the back side are damaged from hitting an engine mount bolt that backed out.
Old 02-19-2018, 04:42 PM   #9 (permalink)
Katch_me's Avatar
1) donít know. Not stock. Iíll post a pic.
2) it is constant. More noticeable when on the throttle.
Old 02-19-2018, 10:00 PM   #10 (permalink)
19-20 Mileage:
18-19 Mileage: TBD
17-18 Mileage: 2500
16-17 Mileage: 2800
Riding Since: 1975
probably a bent drive shaft
