Ecu code 23 - HCS Snowmobile Forums
Old 01-19-2018, 08:13 PM   #1 (permalink)
Member
Default Ecu code 23
2012 F1100 Turbo - ECU code 23. Comes on intermittently while riding as well as running rough while displaying this code. Sometimes it will run poor just before the code pops up and sometimes the code comes up with no driveability issue. Can anyone confirm this is a Mag coil code and NOT an injector code. Seems to be a little confusion out there regarding the trouble code list and descriptions for this sled. Thanks
fullthrottle1 is offline   Reply With Quote
Old 01-20-2018, 08:18 AM   #2 (permalink)
Twinrats496's Avatar
Current Sled(s): 12 XF 1100 Turbo
Previous Sled(s): 04 ZR900, 98 ZRT w/1000D&D, 93 T-Cat, 86 600 Indy w/707 SLP,
Favorite Riding Area: U.P.
18-19 Mileage 1500
16-17 Mileage: 1900
15-16 Mileage: 2100
Riding Since: 1964
Code 23 is the Secondary Fuel Injector on the Mag Side Cylinder.
Might want to remove the injector connection and check for any corrosion or the cap itself not being snapped on properly.
Also if you've had the ECU harness off check that also.
Twinrats496 is offline   Reply With Quote
Old 01-20-2018, 03:49 PM   #3 (permalink)
Member
Thanks will check out
Old 01-21-2018, 01:09 PM   #4 (permalink)
Tinsoldier's Avatar
Favorite Riding Area: anywhere cold and white
Not according to Krom here from this other thread:
all ecu codes are on a white sticker on the belt guard
1 Failure in the fuel system.
2 Failure in injector (PTO).
3 Failure in injector (MAG).
4 Failure in barometric pressure sensor.
5 Open or short circuit in intake manifold air temperature sensor.
6 Open or short circuit in water temperature sensor.
7 Open or short circuit in throttle position sensor.
8 Open or short circuit in manifold air pressure sensor.
9 Failure in crankshaft position sensor.
11 Failure in speed sensor.
12 Failure in coil (MAG).
13 Failure in coil (PTO).
14 Failure in ISC valve.
15 Failure in oxygen sensor.
19 Failure in camshaft position sensor.
21 Failure in knock sensor.
22* Failure in coil (PTO secondary).
23* Failure in coil (MAG secondary).
25 Failure in shifting system/gear position switch.
OCTN* Low octane gasoline.
* Turbo models
Tinsoldier is offline   Reply With Quote
Old 01-21-2018, 01:48 PM   #5 (permalink)
18-19 Mileage 1500
16-17 Mileage: 1900
15-16 Mileage: 2100
Riding Since: 1964
Here's what the sticker on my sled says, which is also a '12 Turbo just like the OPs sled.
Name:	Error Codes.jpg
Old 01-21-2018, 02:19 PM   #6 (permalink)
Member
That's effed up. My sled doesn't have the original belt guard on it so I don't have the sticker and apparently there's more than one version of the sticker
Old 01-21-2018, 07:58 PM   #7 (permalink)
18-19 Mileage 1500
16-17 Mileage: 1900
15-16 Mileage: 2100
Riding Since: 1964
Sorry I can't explain the difference between the two.
I'd say ask Krom but I think he's been banned from HCS.
