TD ben's outlaw on ice... 4.60 @ 148mph - HCS Snowmobile Forums
Closed Thread
Old 03-27-2016, 12:28 PM   #1 (permalink)
HCS Advertiser
Turbo Dynamics's Avatar
Default TD ben's outlaw on ice... 4.60 @ 148mph
Well the sled hooked this time...
At lower boost we ran 4.6 @ 147mph twice.
Cranked boost up went for the kill. 4.60 @ 148 mph but slipped the belt bad for 180 feet. Without belt slip that was an easy 4.5 @ 150mph. Sled is an animal.
Ice went soft and we didn't even try to take the clutch apart to change the weights that's 45 minutes and the temp was already 6 degree celcius (47F and sunny).
We knew by the time the clutch was ready we would blow the track right off...
so officially at 800lbs race weight with 195 lbs driver Slipping the belt bad... 4.60 @ 148 mph and 1.06 60 foot, 139mph in 500 feet. we ran 155mph TD GPS in 750 feet... what a brute !!!
Unofficially I know for a fact that was a 4.5 @ 150mph+ in 660 without slipping the belt. For an 800lbs PIG I'm more than happy.
First time out on not so good ice and rough last minute homemade track (bumpy)
At 800lbs race weight 200 lbs more than most other outlaw sled
Videos are VERY nice. Will upload tonight or tomorrow
1-800-549-0246
2009-2015 1100 turbo 4 stage ECU REFLASH, 200-273HP on pump gas up to 320HP on race fuel. Fastest stock turbo E.T. on grass 4.46 at Haydays 2013 (Priceless sled)
Turbo Dynamics is offline
Old 03-27-2016, 12:34 PM   #2 (permalink)
HCS Advertiser
Td gps times confirmed via stalker radar to be ultra accurate as if we didnt knoe that already but skeptics will always be.
ID:	1661545   Click image for larger version
ID:	1661553   Click image for larger version
ID:	1661561   Click image for larger version
ID:	1661569   Click image for larger version
ID:	1661585   Click image for larger version
ID:	1661593   Click image for larger version
ID:	1661601   Click image for larger version
ID:	1661609   Click image for larger version
ID:	1661625   Click image for larger version
ID:	1661633   Click image for larger version
ID:	1661649   Click image for larger version
ID:	1661657   Click image for larger version
ID:	1661673   Click image for larger version
ID:	1661681   Click image for larger version
ID:	1661689   Click image for larger version
ID:	1661697   Click image for larger version
ID:	1661713   Click image for larger version
Old 03-27-2016, 12:43 PM   #3 (permalink)
HCS Advertiser
I'd love to thank STM for making this big clutches that can put over 650 HP down in a 800lbs sled. Yes I think I made 700HP on the last pass and slipped but I know exactly what to do next time. Geared for grass even at that weight I believe this sled to run excellent number as is...
It's going on a diet as soon as possible we should shave 150lbs out of it. We ran a 3.85 @ 139mph on the ice in 500 feet. Pretty stoked about that too
1-800-549-0246
Old 03-27-2016, 12:53 PM   #4 (permalink)
oly
What brand and size of turbo are you using ?
oly is offline
Old 03-27-2016, 12:55 PM   #5 (permalink)
HCS Advertiser
Precision housings but for the rest good luck trying to find that. I built this turbo custom myself and I'm not giving out the specs. It works too good to share... sorry !
I'm already working at a disadvantage with a smaller CC motor (not stroker) stock head and stock cams I can't give out my turbo recipe...not yet. I will later this winter after going to a few races.
1-800-549-0246
Old 03-27-2016, 01:15 PM   #6 (permalink)
oly
what standalone are u using ?
oly is offline
Old 03-27-2016, 01:18 PM   #7 (permalink)
HCS Advertiser
Stock ECU with TD big turbo map. Exact same mapping I sell my customers with big turbos. Except I'm running 1000cc injectors X 4 instead of four 750cc...
with slightly lower base FP and leaned out idle. And I run a large Bosch 044 pump. I'm maxed out fuel wise at the moment but I make plenty power we just need to lighten her up.
1-800-549-0246
Old 03-27-2016, 01:36 PM   #8 (permalink)
oly
Ok,Thanks for the all info !!
oly is offline
Old 03-27-2016, 01:40 PM   #9 (permalink)
HCS Advertiser
https://m.youtube.com/watch?v=LXFvLzH9OVE
1-800-549-0246
Old 03-27-2016, 06:06 PM   #10 (permalink)
cropsprayer's Avatar
Current Sled(s): 2 z1 turbo & Blacke
Previous Sled(s): to many to list
Favorite Riding Area: where ever there is snow
18-19 Mileage 1900
Riding Since: 1955
wow I sure like watching those videos, Its like almost like being there, Also it sounds and looks like you are getting it pretty close to where it needs to be other than that belt slip. now as far as the diet you cant I say you CAN NOT DRINK ANY BEER FROM NOW TILL EARLY WINTER LOL, Keep up the good work.
cropsprayer is offline
Closed Thread
