Switchback Assault Clutching - HCS Snowmobile Forums
Old 01-05-2020, 02:09 PM   #1 (permalink)
Newbie
11mnassault's Avatar
Current Sled(s): 2011 Polaris SBA 800
Favorite Riding Area: Northern WI
Riding Since: 2002
Default Switchback Assault Clutching
Hi guys, long time reader but this is my first post as I bought my first sled early this winter. Picked up a 2011 SBA with 4300 miles. Top-end was rebuilt with a BMP "Fix-IT" kit and has the 1.352" track. It has been running strong (always starts first or second pull) only it seems to rev only until 7700rpm. I know peak power is made at higher rpm and the general rule is to shoot for about 8200-8250rpm. I am running at sea level (0-1000ft) The guy gave me two sets of clutch weights, 10-66 and 10-68. The 10-68 are currently installed, and with those, it revs to about 7700rpm at the highest. If I'm riding at sea level do you thing putting in the 10-66s will solve my problem? What are the stock weights? Any advice would be greatly appreciated, just trying to help my sled run as best as possible and I know you guys have the knowledge to help me make that happen, Thanks in advance!
11mnassault is offline   Reply With Quote
Old 01-05-2020, 03:34 PM   #2 (permalink)
ivar's Avatar
Current Sled(s): 2019 SBA 850
10-66 was stock in mine. It revved to 8250-8300. I'd try those first.
Also new springs in the clutches if unsure of age
2019 SBA 850,2015 600 Adventure (int'l)
09 Doo 1200 GTX, 02 XC800 / 00 XCR800 - Pro-X rear skid, 99 XC700SP
RIP: 800SBA, 02 XC800, 99 SKS700, 97 XLT SKS
ivar is online now   Reply With Quote
Old 01-05-2020, 04:31 PM   #3 (permalink)
Lexuslover's Avatar
Current Sled(s): 2012 Switchback Pro R 800
Previous Sled(s): 2001 800XC 1999 XLTSP
10-66 is stock. switch the 68s out to 66 and you should be hitting the 8050-8100 you need. and yes, new springs do wonders.
Name:	Screen Shot 2020-01-05 at 2.33.44 PM.png
Lexuslover is offline   Reply With Quote
Old 01-06-2020, 07:42 AM   #4 (permalink)
Current Sled(s): 17 800 pro s s/b
Favorite Riding Area: The Highlands
Riding Since: 12
Condition of belt? Clean valves? Rollers in primary clutch? Not going to gain 500 rpm with stock 66gram weights. Something else is going on.
mtzz is offline   Reply With Quote
Old 01-06-2020, 10:28 AM   #5 (permalink)
Current Sled(s): 2013 Rush Pro R 800 retro 2001 XCSP 700
19-20 Mileage:
18-19 Mileage: 1400
17-18 Mileage: 1200
16-17 Mileage: 1000
It's possible some parts are worn in the primary clutch too. Could be a lot of things. My XC would only rev to 7600 when I first got it, it was a combo of worn rollers and pins, clutch weight bushings, weak springs, etc. Rebuilt the primary clutch and it came alive.
But as said above, a new belt, fresh springs in both clutches, a delrin washer in secondary, clean valves, check belt and chain tension, and make sure clutch is in good condition. Also, TPS could need adjusting. The joys of a snowmobiler, lol. That is a fun machine though and worth getting to run tip top
If your primary spring is weak, or broken? A new one with the 66's could fix it up too. It's common for those springs to break, and would cause low rpm.
Frankie406 is offline   Reply With Quote
