2013 Switchback Assault pushing into corners - HCS Snowmobile Forums
Like Tree1Likes
  • 1 Post By sayatodaU.P.eh?
Old 12-09-2019, 06:09 PM   #1 (permalink)
Newbie
Default 2013 Switchback Assault pushing into corners
I recently added Woody's Dooly 6" carbides to prevent darting on my 2013 Switchback Assault. Went out to try it this weekend and noticed significant pushing into the corners. The snow was a bit loose, but I generally have never had any issue with pushing. I love the feel of them on straight runs, but looking to prevent the pushing. Any adjustments I can make to the set up to fix or decrease this?
ttardie is offline   Reply With Quote
Old 12-09-2019, 06:47 PM   #2 (permalink)
Administrator
sayatodaU.P.eh?'s Avatar
Current Sled(s): 2015 RMK 800
Previous Sled(s): 600 H.O. Fusion
Git rid of the dually carbides. Seriously. Every sled Iíve ever ridden with them, in anything less than a good hard/setup trail, pushed like a dump truck.
northstarrick likes this.
sayatodaU.P.eh? is offline   Reply With Quote
Old 12-09-2019, 08:48 PM   #3 (permalink)
maydaze's Avatar
Current Sled(s): 12' S/B Assault 09' IQ600 136" 04' XC800 mod
Previous Sled(s): 2 Alouettes 1 Doo 15 Polaris
Favorite Riding Area: Great Sacandaga Lake
19-20 Mileage:
18-19 Mileage: 600
17-18 Mileage: 485
16-17 Mileage: 507
Riding Since: 1970
When I had 171 studs down the middle I ran Woodys 8' carbides. Turned perfect with no push. I now have 192 studs going all across, triggers and chisels and I have a slight push when the snow is loose. If the snow is firm, a light touch of the brake lever to set the front end and it turns fine. I did try 9" Shaper bars shortly and no push what so ever. But they are aggressive. If I played with the weight transfer and ski pressure I could most likely make it easier. 144" with the 1.3" Cobra track.
HAMMER DOWN!!!
maydaze is offline   Reply With Quote
Old 12-09-2019, 10:08 PM   #4 (permalink)
Newbie
Thinking I could turn up the preload on the front springs to see if that helps. Don’t know that I should mess with the springs in the back at all?
Old 12-09-2019, 11:42 PM   #5 (permalink)
Check your toe-in on the skis.
2sewings is offline   Reply With Quote
Old 12-10-2019, 09:06 AM   #6 (permalink)
HCS Advertiser
northstarrick's Avatar
dually anything suck. they remove darting in some cases but won't turn. we don't even stock or sell them. worse choice of runners out there. if your trying to remove darting? set your sled up right. shim the ski's if needed. darting is from three things. a toed in sled, to much ski pressure, not enough ski pressure. in the later pushing will also be a effect.
Stage 1,2,3 clutch kits
Oil tank vent kits
Doo T-Stat bypass kits
Rush/Axys A-Arm bushing kits
550 fan upgrade kit
Authorized dealer for
SLP
RK-Tek
WPS
US Chrome
Thunder Products
Automatic Distributors
Venom/Team Ind.
Redline Oil
Klotz Racing Synthetics
K100
