Cracked crankcase - HCS Snowmobile Forums
Old 03-19-2019, 09:36 PM   #1 (permalink)
Member
ILSummit's Avatar
Default Cracked crankcase
Picked up a project 13 Pro RMK 800. Iím assuming sled has some seriously bad detonation, lower rod bearing on pto side is non existent. Put a nice little hole in the case and chewed it up pretty good. I know cases can be welded, but with this one being so chewed up makes me worried. Posting some pics and looking for some input. Iíve got a line on a 14 motor with a Carlís 900 big bore. This sled is currently turbo charged. Think I should rebuild factory motor and stay boosted or go big bore? Thanks for any input!
ILSummit is offline   Reply With Quote
Old 03-19-2019, 09:37 PM   #2 (permalink)
Member
ILSummit's Avatar
It also chipped this ring groove on the upper case.
Old 03-19-2019, 09:49 PM   #3 (permalink)
fourh-ds's Avatar
Current Sled(s): 00 XCR 800, 04 XC 800
Riding Since: 1988
I don't know anything about the big bore you asked about. But in regards to the pictures, as long as the bearing journals are still true and stay that way after welding, it should be safe to use.
fourh-ds is offline   Reply With Quote
Old 03-19-2019, 09:59 PM   #4 (permalink)
Member
ILSummit's Avatar
Ok thanks for the reply, just makes me nervous cause seemed like the rod may have thinned out the cases but I may be overthinking it.
Old 03-20-2019, 12:32 AM   #5 (permalink)
polaris bob's Avatar
Current Sled(s): The Frankenstein
Favorite Riding Area: Anywhere there is snow.
Riding Since: 1992
Personally, I would go with new cases. Especially if you're going to go turbo again.
polaris bob is offline   Reply With Quote
Old 03-20-2019, 03:11 AM   #6 (permalink)
Perfectly safe to weld those cases, I’ve had many repaired that were FAR worse. Those are non stressed areas so they don’t matter if there is a repair.
The chipped ring groove won’t cause you any issues either, but it is a result of improper crankshaft removal. It shows that the crank was knocked out of the cases at an angle instead of straight on.
Nick_R_23 is offline   Reply With Quote
Old 04-01-2019, 06:58 PM   #7 (permalink)
Current Sled(s): 2013 Rush Pro R 800 retro 2001 XCSP 700
19-20 Mileage:
18-19 Mileage: 1400
17-18 Mileage: 1200
16-17 Mileage: 1000
Like Nick said, that's no big deal. If you want someone good to weld it who has done a bunch of those, and has a special mandrel that fits tight in the bearing housing bores and keeps them true while welding, and also is a certified master welder, Jwsnoweld.com He isn't to far from you as far as shipping goes.
Or, if you want to buy new cases, I will buy that case from you.
Frankie406 is online now   Reply With Quote
Old 04-01-2019, 10:32 PM   #8 (permalink)
HCS Advertiser
northstarrick's Avatar
i had my wife's 600 pro-r case welded. it had a quarter size hole out through it and i didn't have the piece that was missing. my brother machined it after welding and we bead blasted the case after that. you can't tell is was ever repaired. that was 4000 miles and four years ago.
Stage 1,2,3 clutch kits
Oil tank vent kits
Doo T-Stat bypass kits
Rush/Axys A-Arm bushing kits
550 fan upgrade kit
Authorized dealer for
SLP
RK-Tek
WPS
US Chrome
Thunder Products
Automatic Distributors
Venom/Team Ind.
Redline Oil
Klotz Racing Synthetics
K100
Old 04-01-2019, 10:40 PM   #9 (permalink)
Member
ILSummit's Avatar
Cool, Iím gonna have it welded. Iíve cleaned them up but havenít sent them anywhere yet, was still looking around. Iíll look into who you recommended.
When I found the crack I definitely thought I was screwed, nice to know they can be welded back together. Thanks for the input
Similar Threads
Need Help With Crankcase Pressure Causing Oil On Airfilter bisonboy02 Turbo 4 Stroke 18 12-21-2019 08:44 PM
Cracked head '17 ZR9000 LTD Turboflash Turbo 4 Stroke 14 01-31-2019 02:27 PM
600 VES crankcase slot and bearing ring placement jkaiser Polaris General Discussion 0 01-17-2019 11:31 AM
Crankcase Pressure bisonboy02 Turbo 4 Stroke 1 03-11-2017 11:16 AM
700 ves crankcase question. 340 TX-L XC 5 01-05-2017 08:48 PM
