Re: Need help with a 14 pro 800 tps/plug issue - HCS Snowmobile Forums
Old 01-16-2017, 03:35 PM   #1 (permalink)
Newbie
Default Re: Need help with a 14 pro 800 tps/plug issue
Yesterday down the trail my 14 pro 800 threw a CEL. It would idle fine but once I gave it throttle it'd bog down and not move but it didn't kill itself.
So after putting the brake on and a combination of hitting mode/select I finally got 520194 with a 3 under it to come up . I pulled the plugs they were pretty gnarly (oily) so I popped 2 new ones in and it ran fine and the CEL went away.
I do have my oiler up about 2.5, but in my 300 ish miles I haven't had this issue.
After a google search I found a thread on here about a guy with a 12 assault throwing the same code, Throttle Release Signal and the 3 indicates that it's receiving Voltage Too High . But since my CEL isn't on anymore I am thinking my issue is gone?
Did my ast field yesterday and the light popped up before we started doing beacon searches. There was no snow/ice around the throttle, the light came on and it would idle find but would bog hard with throttle and not move, but it wouldn't kill itself. So we did the beacon searches then I changed my plugs (the tips/electrode seemed fine but the threads were a little oily), it still had the light on so I feathered the throttle a bit and it eventually revved up normally and ran fine for the rest of the day with no light)
I didn't check the code that came up but I am assuming it was the same 520194, if I bring it in to the dealer would they be able to tell exactly what the issue is with there digital wrench?
Also, I should add I have been running the sled in ethanol mode this season b/c I've been filling it up with 91 that 'may' contain up to 10% ethanol. For plugs I have been using the NGK br9es, I am going to get a couple sets of the iridium ones as well b/c I've read they are good
gdhillon is offline   Reply With Quote
Old 01-17-2017, 08:58 AM   #2 (permalink)
HCS Advertiser
northstarrick's Avatar
the plugs should be bpr9es? replace your throttle safety switch. and or first make sure your throttle lever free play is the width of a credit card? bad throttle safety switches are a common problem.
Stage 1,2,3 clutch kits
Oil tank vent kits
Doo T-Stat bypass kits
Rush/Axys A-Arm bushing kits
550 fan upgrade kit
Authorized dealer for
SLP
RK-Tek
WPS
US Chrome
Thunder Products
Automatic Distributors
Venom/Team Ind.
Redline Oil
Klotz Racing Synthetics
K100
Old 01-28-2017, 08:13 PM   #3 (permalink)
Newbie
Took it to the dealer it was the TSS. Is it a bad ideas to bypass it? Incase this issue ever happens again in the hills
Old 01-28-2017, 08:14 PM   #4 (permalink)
Newbie
My flapper def has more play than a cc width I will tighten that up
