chain case - Page 2 - HCS Snowmobile Forums
ProClimb (2012 - ) M 800/1100/
Like Tree5Likes
Old 03-09-2019, 10:33 AM   #11 (permalink)
chevrolettough's Avatar
Current Sled(s): 2015 Arctic Cat XF8000 High Country
Previous Sled(s): 2007 Acrtic Cat Crossfire 800 Sno Pro
Favorite Riding Area: top secret.
19-20 Mileage: 1200
18-19 Mileage: 150 :(
17-18 Mileage: 325
16-17 Mileage: 2
Riding Since: 2002
The chain case fluid isnít expensive. Got the seal.
Pretty sure i need to drill holes in the skid plate I put on for drainage...
Also how the hell do you get to the bottom screws, Jesus it looks tight.
2015 XF 8000 High Country Sno Pro--------------------------------------
Hygear Float 3's
Speedwerx y pipe and silencer
Hypershift primary
AC led hand guards
chevrolettough is offline   Reply With Quote
Old 03-09-2019, 11:28 AM   #12 (permalink)
CRASH74's Avatar
Current Sled(s): '13 XF 800 High Country
Previous Sled(s): '07 Xfire 800, '08 Xfire 800 Sno Pro
Favorite Riding Area: somewhere with snow
Riding Since: 1979
You have to get to them from underneath the belly pan. The chaincase sits below the belly pan which has molded plastic pan to cover it. There are two holes, one at the front and one at the back for accessing the screws and on in the center for drainage. If you put on a heavy duty rear skid plate like I did then you would need to drill holes in it to match in order to be able to access the screws.
As far as changing the fluid annually, you don't have to do it more than once a season unless you have an extenuating circumstance. It should be done at the end of the riding season before it goes into storage for the summer, that way you can inspect gears, chain, adjuster and all that and have fresh fluid that you know doesn't have any moisture in it.
ID:	2047764   Click image for larger version
chevrolettough likes this.
CRASH74 is offline   Reply With Quote
Old 03-10-2019, 10:06 AM   #13 (permalink)
19-20 Mileage: 1200
17-18 Mileage: 325
16-17 Mileage: 2
Riding Since: 2002
Son of a! Yep going to have to drill holes! And fully agreed on the annual swap, it what i did with my old diamond drive.
Thanks for the info and pics, VERY helpful!
Hygear Float 3's
Hypershift primary
AC led hand guards
Old 03-10-2019, 10:40 PM   #14 (permalink)
CRASH74's Avatar
Riding Since: 1979
You're very welcome, any other questions just ask.
Old 03-11-2019, 10:03 AM   #15 (permalink)
19-20 Mileage: 1200
17-18 Mileage: 325
16-17 Mileage: 2
Riding Since: 2002
Holes are drilled and case was loosened and the oil drained over night. My rip cord broke yesterday so weíre replacing that too . Had to use the emergency kit. And just like you guys said, hood and exhaust had to come off. They had to come off for the rip cord replacement anyway. Might do plugs too since itís all open. Pics to follow. Snow has been amazing!
Hygear Float 3's
Hypershift primary
AC led hand guards
Old 03-15-2019, 02:02 PM   #16 (permalink)
skidooboy's Avatar
cobra cord for the recoil, for the win! Ski
"you are only as smart as your right thumb"
skidooboy is online now   Reply With Quote
Similar Threads
Chain case cover replacement dreamweaver25 Turbo 4 Stroke 15 01-04-2018 01:05 PM
Chain case oil level LM53 Turbo 4 Stroke 27 12-11-2017 08:02 PM
Striped chain case allen head teamdirtbag XC 32 12-06-2017 12:21 PM
